Old 04-27-2019, 02:31 AM   #1
M2M
M2M's Avatar
Arrow Could these 6v LEDs be used as tail lights?
Could these 6v LEDs be used as tail lights instead of turn signals? They are being sold by the suppliers as turn signals as they have a pre-loaded resistor built in so it will work with a thermal flasher.
M2M is offline   Reply With Quote
Old 04-27-2019, 06:42 AM   #2
wmws
Default Re: Could these 6v LEDs be used as tail lights?
I don't see why not.
wmws is offline   Reply With Quote
Old 04-27-2019, 07:01 AM   #3
Bill Pursel
Bill Pursel's Avatar
led lights are polarity sensitive may not work with positive ground system
Bill Pursel is offline   Reply With Quote
Old 04-27-2019, 08:42 AM   #4
Badpuppy
They will work for taillights provided the polarity is right for your car, as Bill says. The built in resistor draws the same current as a filament bulb, so no energy savings, just extra heat. But LEDs last a long time.
Second thought - the extra heat may cause a problem if the resistor is inside the housing. They're not intended for continuous duty.
Badpuppy is offline   Reply With Quote
Old 04-27-2019, 10:40 PM   #5
M2M
M2M's Avatar
Polarity I think is no issue with these as they are made for As and sold by all the suppliers.
The resistor is inside the housing apparently, so I guess no deal with these as tail lights.
Old 04-28-2019, 02:15 AM   #6
29vintage
I use the X arc Duo Led lights.
http://www.hightechspeed.com/products/xarc/index.html
They are not the cheapest around but work brilliantly on the rear. Have them tucked up under the body on each side, so not readily visible.
The yellow gives a bright turn signal. Then you also have the full red for stop, and dimmer red for tail. I have both red leds through an additional switches under the rear seat. That way I can turn the additional stop and/or tail lights on if I want additional rear lights, such as when out on the highway or driving at night.
The combination of turn signal and additional stop and tail lights in one neat package is hard to beat. I run 12v so not a problem.
29vintage is offline   Reply With Quote
Old 04-28-2019, 10:13 AM   #7
Tinbasher
Tinbasher's Avatar
Check out Logo Lites. They have a kit ready to go for Turnsignals, Brakes Etc.
Tinbasher is offline   Reply With Quote
Old 04-28-2019, 11:30 PM   #8
M2M
M2M's Avatar
Originally Posted by 29vintage View Post
No good for me as they will not work with 6v.
