Old 02-23-2024, 03:41 PM   #1
Grayble 123
Grayble 123's Avatar
Default Throw out bearing/ clutch fork
I’ve been fighting “clutch chatter” since I bought my ‘51 coupe back in the fall. I older gentleman I bought it from purchased it from a friend of his and said the friend replace the clutch. When bought the car it had terrible chatter. I resurfaced the flywheel and replaced throw out bearing, pressure plate and disk. Which no change to the chatter. But at the time shoebox central was out of the hubs so I reused the old one. The hub had a damaged clip. Finally found a hub and bearing combo on eBay. So this afternoon I removed the transmission the old bearing and hub was trashed. When I tried to install the new hub/bearing it seems a little wider than the fork tips. My question is has anyone else had the same issue? I’m wondering if I the clutch fork I have is the wrong one. Or does everyone have to modify the clips to make them fit?
Grayble 123 is offline   Reply With Quote
Old 02-23-2024, 04:57 PM   #2
Ggmac
Default Re: Throw out bearing/ clutch fork
I’m hoping someone with better memory than me chimes in but I’ll go out on a limb and say you bought an early (large) throw out bearing and carrier . They changed sizes in 49 I think . All earlier (?) will be larger than the 49 up .
Old 02-23-2024, 07:05 PM   #3
Grayble 123
Well that’s what I’m afraid of. They sent me the wrong part and now I’m down until I can find the right one. Everybody that carries the bearing hub combination is out of stock.
Old 02-23-2024, 07:12 PM   #4
kurt v
can you push the bearing out of the hub and go to a auto parts stor to get a bearing.
kurt v is offline   Reply With Quote
Old 02-23-2024, 07:50 PM   #5
Grayble 123
Bearing isn’t the issue it’s the hub that is hard to find.
Old 02-23-2024, 08:50 PM   #6
tubman
tubman's Avatar
It's probably not much help, but if all else fails, I believe I have an extra in my shop in Minnesota. Unfortunately, I'm in Florida until the middle of May.
As always, a good source for oddball stuff like this is our own Fred Wilner at "Southside Obsolete", "barnfind08" on this forum. Have you tried "Third Gen Automotive"?
Old 02-23-2024, 09:27 PM   #7
Grayble 123
I’m interested. Send me a message when you get home. Thank you
Old 02-24-2024, 07:16 AM   #8
deuce lover
deuce lover's Avatar
Try Southside Obsolete in MN
Old 02-24-2024, 07:21 AM   #9
Grayble 123
Deuce Lover I’m going to call them.
Old 02-24-2024, 07:34 AM   #10
chap52
chap52's Avatar
Mac Van Pelt may be able to help with the correct part. Chap
http://www.vanpeltsales.com/
Old 02-24-2024, 09:05 AM   #11
deuce lover
Quicker to send an email as he is not always near the phone. He will respond,always does.He has 6 bldgs of NOS Ford parts
Old 02-24-2024, 09:38 AM   #12
Grayble 123
Deuce Lover I just sent an email.
