08-22-2022, 03:32 AM | #21 | |
Re: Windage tray yes or no
08-22-2022, 05:22 AM | #22 |
Who knows about what Ford did and didn't do . . . in many cases things were done to save costs. Also, at the lower RPMs that most folks ran their engines - probably didn't make a whole lot of difference.
08-24-2022, 10:04 AM | #23 |
A little investigating has yielded a few pictures of the 49-53 Merc pan and windage tray. It seems that with some modification the tray portion could be fitted to the 59A pan. Might even be simpler to just fab a new one.
Thanks to everyone who has responded . Keith |
08-24-2022, 11:22 AM | #24 |
08-24-2022, 11:49 AM | #25 | |
Here's what I believe is a "51" pan Ronnie mentions. |
08-25-2022, 02:29 AM | #26 |
As for HP, most windage trays will be in the single digits. Many claim no HP increase. I've only run one, back in the 60's, on a 427 and did no A/B test, to see if it increased HP. Anything you can do, to control the oil will be beneficial, especially in keeping the upper oil, off the crank. Try to route it to the front and rear of the engine. Little things here and there can always help. Regarding the pictured 49/51 pan, it is not a windage tray, that is a baffle and a fairly well designed one. Great for cornering, stops, starts and steep hills. It separates the aerated oil from the pan oil but, doesn't to anything to control and condense that oil. Ford may have added it to see if it reduced warranty claims, found it didn't and removed it from the last two years. My only guess?
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
08-28-2022, 12:13 PM | #27 |
I think I have come up with a plan "A" (least used plan in the world).
Fabricate a tray closely resembling that used on the 50s Mercury. I think that it will improve oil control and should be rather simple to fabricate. It would be helpful,however, if I could get a few dimensions off an original Merc pan. Any help along that line would be appreciated. Keith |
08-28-2022, 08:21 PM | #28 |
Keith I can help with some measurements of the windage tray installed in the Mercury pan and the correct pickup as well send me a PM.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
08-29-2022, 10:40 AM | #29 |
Some observations made some time ago on location of tray.
