Old 09-12-2021, 11:13 AM   #1
fastroadster
Default Horn button
Is there a way to clean contact on a model a horn button. It works sometimes and I was wondering if there is a way to clean it.
fastroadster is offline   Reply With Quote
Old 09-12-2021, 12:06 PM   #2
katy
katy's Avatar
Default Re: Horn button
Not w/out disassembling it.
Old 09-12-2021, 12:53 PM   #3
arefftx
I had a short in the wiring inside the horn that was causing problems might check that also
arefftx is offline   Reply With Quote
Old 09-12-2021, 01:24 PM   #4
Dave N.
My Horn button does the same to, I find that if i put my palm flat on the button and push down and turn my hand back and forth like a windshield wiper, it will work for a couple months . But i do need to remove it and get it good and clean.
Dave N. is offline   Reply With Quote
Old 09-13-2021, 07:15 AM   #5
Russell Reay
I just filled all the cracks in my steering wheel and painted it flat black, The steel dish (in the center where the nut goes) was cruddy and is now painted. Is it necessary to restore this to bare metal for a good horn ground ? I have a new horn button and repair wire on order.
Russell Reay is offline   Reply With Quote
Old 09-13-2021, 07:44 AM   #6
chrs1961815
chrs1961815's Avatar
Not really - the horn wire runs through the horn rod and only touches anything at the light switch. Horn works by grounding it out.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 09-13-2021, 08:28 AM   #7
Badpuppy
The button with wire attached makes contact at its edges with a grounded metal ring which must have a clean surface. The contact at the lighting switch is a wiper to maintain horn connection while turning.
Old 09-13-2021, 05:40 PM   #8
fastroadster
could it be possible I have grease build up or crud my lightning switch. If I cleaned it and put on contact spray. Do you think that would work. Hate to pull everything apart if I don't have to
