Old 05-13-2018, 06:26 PM   #1
Colonel
Default Blowing Steam out Exhaust Pipe
Yesterday my very reliable 31 tudor was difficult to start and noticed after the car warmed up a lot of steam coming out of the exhaust pipe. See a drop in level in radiator. No water in oil pan so far.
Presume it is the head gasket has failed but what other checks can I make before I start on pulling the head?
Thanks
Colonel is offline   Reply With Quote
Old 05-13-2018, 06:37 PM   #2
Bulligen
Bulligen's Avatar
Default Re: Blowing Steam out Exhaust Pipe
You could take out the plugs and see which ones are steamed cleaned and you will know which cylinders are affected?
Bulligen is offline   Reply With Quote
Old 05-13-2018, 07:56 PM   #3
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Also a compression test. However, the only way to know for certain is to pull the head and look.
Old 05-13-2018, 08:01 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
With the plugs out, let it sit awhile & spin it over & see which holes are blowing WATER or MIST.
Bill Selftest
"THE ASSISTANT GURU OF STUFF"
Old 05-13-2018, 09:01 PM   #5
jm29henry
jm29henry's Avatar
Head gasket sounds probable to me
jm29henry is offline   Reply With Quote
Old 05-13-2018, 09:56 PM   #6
Synchro909
Synchro909's Avatar
Yup, head gasket is the most likely, I think. Next would come a cracked block or cracked head. I've even seen rust from the water jacket go right through the block and open a hole into the inlet manifold. Boy, did that one blow steam!
Time to whip the head off it and take a look. How long is it since you checked the tension on the head studs?
Old 05-14-2018, 12:24 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Check head nut torque first.
Old 05-14-2018, 06:57 AM   #8
George Miller
George Miller's Avatar
Bill Selftest
Good idea
George Miller is offline   Reply With Quote
Old 05-14-2018, 07:04 AM   #9
SeaSlugs
SeaSlugs's Avatar
I second this idea, then I would run a compression and leakdown test. Will help pinpoint what cylinder(s) are affected in case it is a crack.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-15-2018, 01:17 PM   #10
burner31
burner31's Avatar
Steam you say?
Keith
Shawnee OK
'31 SW 160-B
Old 05-15-2018, 10:25 PM   #11
BILL WILLIAMSON
Along with the vapor, IF it DRIPS off the end of the tailpipe, you could sublet it out, as a STILL!---LOL (hic!)
Bill W.
Old 05-15-2018, 10:52 PM   #12
Art Newland
Art Newland's Avatar
See post #7, read it, then do what it says!
"whatever works!"
Art Newland is offline   Reply With Quote
Old 05-16-2018, 07:29 AM   #13
chap52
chap52's Avatar
Would be great if a little bolt tightening would solve the issue. Sure worth a try.
Let us know, thanks, Chap
