Old 09-03-2023, 09:39 AM   #1
tucker6077
Default Flathead V8
Hello Everyone ! The motor in my 33 was supposed to have been rebuilt 100 miles ago. My question is I have oil showing up on a few plugs that are firing?
tucker6077 is offline   Reply With Quote
Old 09-03-2023, 03:16 PM   #2
Boggus Deal
Default Re: Flathead V8
Just 100 miles? I’m sure the rings haven’t even begin to get broken in well!
Boggus Deal is offline   Reply With Quote
Old 09-03-2023, 03:50 PM   #3
tubman
tubman's Avatar
Depends on the type of rings, doesn't it? Old style cast iron rings take a while and chrome is even worse. Modern Moly rings are said to break in almost immediately. I would suggest you go back to the source and see what was installed.
tubman is online now   Reply With Quote
Old 09-03-2023, 07:14 PM   #4
Bored&Stroked
Bored&Stroked's Avatar
It depends on a lot of things . . . the machine work, the tolerances, the quality of the rings, has the engine been put under load to break them in, etc.. I won't speculate here, but my suggestion is to go run it hard - full accelerations for low speed, multiple times to see if that helps the rings seat. Also, without a leak down test, hard to really know if you have an issue and what it is.
Old 09-03-2023, 07:25 PM   #5
Krylon32
Bored&Stroked has it right. Ride it hard and put it up wet as they say.When done do another check. You got nothing to lose.
Krylon32 is offline   Reply With Quote
Old 09-04-2023, 06:55 AM   #6
mfirth
Also, if there are any hills or grades in your area, "lug" it up hill. Make it work hard in 3rd gear if posssible. Long ago an old engine builder had me do this with a rebuilt 6 cylinder and that engine used no or little oil and ran forever.
mfirth is offline   Reply With Quote
