Old 10-19-2021, 02:53 PM   #1
'31 Patina
Default 1957 Ford Country Sedan Transmission Question
I recently bought a 1957 Country Sedan with the original 292 y block and what I believe was called the cruiseomatic or fordmotaic automatic transmission. My question is do I need to start out in the low gear and then shift it to D? If I start out in D am I hurting anything? Is the car actually starting out in 2nd and then shifts to 3rd? I see some people say this transmission is a 2 speed but others say it's a 3 speed. Which is it?
Also, the car is pretty much stock except the previous owner put 2.79 gears in the rear and 15" wheels on it with front disc brakes.
Thanks.
'31 Patina is offline   Reply With Quote
Old 10-19-2021, 03:11 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: 1957 Ford Country Sedan Transmission Question
If it's the original transmission it's a Fordomatic which does start in 2nd if you have the gear selector in the D position. No need to start out in low unless you just want to, although with 2.79 gears there may be an advantage to doing so. Fordo's are 3 speed trannies but normally start out in second as noted above.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 10-19-2021, 03:47 PM   #3
1930artdeco
1930artdeco's Avatar
What Dobie said, I have the exact same car and just sent my tranny out for a rebuild. You are lucky to have the 15" wheels and disk brakes as I still have the drums-for now. Lets see some pics and have you checked out the 57Fordsforever.com site?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-19-2021, 06:32 PM   #4
Gene F
Gene F's Avatar
I have the big drums all the way around on my 57, and my car has good brakes.
1930 Artdeco, will a set of Cragars work on my car with the drum brakes? I mean the back of the wheel the face of the drum? I don't want to do anything that will make the wheels move wider.
Old 10-20-2021, 01:37 AM   #5
1930artdeco
To tell you the truth I am not sure. I have not played with back spacing much. I know there is a section dedicated to wheels on the 57fofdsforever forum. But I just watched a video of a 500 with cragars on it.
Mike
1957 Country Sedan
Old 10-20-2021, 01:07 PM   #6
rotorwrench
rotorwrench's Avatar
The dual range Cruise-O-Matic came out in 1958 but the single range types were still used in a lot of applications.
Old 10-20-2021, 02:49 PM   #7
miker98038
miker98038's Avatar
I had a set of Cragar’s, garden variety in stock, they were 15x6 with 3 or 3 1/2 backspace. They fit the bird, drums no problem. I didn’t care for them on that car. But I think most modern wheels ( modern 14-15”, not the 22” hoops) fit drums without a problem. Check the backspace both ends, and fender skirts if necessary. Ford changed the center hole size along the way, so the later wheels are going to index (?) on the lugs, not the center opening.
It’s almost certainly on the 57 ford site above.
miker98038 is offline   Reply With Quote
Old 10-20-2021, 05:27 PM   #8
Gene F
Gene F's Avatar
I will look, thanks. I don't want to change anything, just new tires and a set of Cragars, with he same width, backspace, etc. I have turbine wheel covers, and don't want to go to the wire wheels.
Old 10-20-2021, 06:35 PM   #9
dmsfrr
dmsfrr's Avatar
Originally Posted by Gene F View Post
... 1930 Artdeco, will a set of Cragars work on my car with the drum brakes? I mean the back of the wheel the face of the drum? I don't want to do anything that will make the wheels move wider.
Gene F,
Many aftermarket wheels have less backspace/positive offset than stock size '57 FoMoCo steel wheels, so they sit a little farther out from the wheel hubs and the wheels are generally wider as well.
If you try to order aftermarket wheels with the width and backspace you want, you may find they're back-ordered forever or 'Unavailable'. I waited just over 10 months for a pre-paid set of these standard offset 15 x 6 Torq Thrust wheels.
Old 10-20-2021, 10:29 PM   #10
40 Deluxe
If it's the original style trans, if you go full throttle right away, it will start in 1st gear and shift to 2nd as soon as you let up.
Old 10-23-2021, 11:54 AM   #11
Gene F
Gene F's Avatar
DMSFRR, are you happy you bought them? On your T-bird? Did they change the look of your car a lot more than you expected?
Old 10-23-2021, 12:16 PM   #12
Gene F
Gene F's Avatar
photo i think the chrome would dress it up a lot.
Old 10-23-2021, 10:10 PM   #13
dmsfrr
dmsfrr's Avatar
Gene F,
They're still in their boxes.
I originally bought them for the red '55 and it was parked for most of the last year due to virus restrictions and it needing some misc. work.
Finally got it out of the garage for the first time about 2 weeks ago, but haven't bought any tires to put on the wheels yet.
photo 1, I'm going for this look even though mine has a white top.
Maybe the white will work well visually with the machined lip of the wheels.
I might use them occasionally on the yellow '57 too, once it gets painted and put back together.
