06-15-2018, 10:57 PM | #1 |
32 Tudor Sedan Door Sill Scuff Plates??
From the short description in David Rehor's book, the scuff plate attaches with #8 pan head screws, and the smallish pic shows the top flange UNDERNEATH the floor mat. But do the screws go in this top flange, or in the vertical flange against the sill side?
Any better pics? Thanks in advance. |
06-16-2018, 01:30 AM | #2 |
Re: 32 Tudor Sedan Door Sill Scuff Plates??
Here is a reproduction scuff plate with the screws in the vertical flange.
06-16-2018, 06:18 PM | #3 |
Thanks for the response, Bill.
BTW, that's one sweet coupe! |
06-16-2018, 07:08 PM | #4 |
On your tudor sedan, unless they have been filled, there should be a string of small holes on top of your sill where the sill plate attached originally. there was only one screw on the vertical surface; one each at the very front of the sill plate. all of the rest of the attachments were on the horizontal surface of the sill. The heads of those on the horizontal surface are concealed by the floor mat/carpeting as shown in the photo below.
The standard and sport coupe sill plates were unique among the '32 body types with screws along both the entirety of the horizontal and vertical surfaces of the sill plates. Last edited by DavidG; 06-18-2018 at 07:18 AM. Reason: grammar and punctuation |
06-16-2018, 11:02 PM | #5 |
DavidG
What will we '32s do when you join Henry? Happy Father's Day. Assuming you have some offspring. And if you don't have biological children, we honor you for your fatherly responses. |
06-17-2018, 10:24 PM | #6 |
Spot on, as always. |
06-18-2018, 07:19 AM | #7 |
Bubsyouruncle and hotrodA,
Thank you for your kind words. |
06-19-2018, 08:54 PM | #8 |
Well....whatta ya know? Found some original (and some non-original) holes right where DavidG said they would be. Figured the equidistant, evenly spaced ones were correct. Laid out and punched holes in the sill plate flange, and got it done. Thanks much!!
