01-05-2013, 08:40 PM | #1 |
What is this and why did it stop working? (Electrical Problem)
Hello, I'd like to thank you in advance for taking the time to read this thread.
Summary: My dad bought a Model A about a month ago. It didn't run and the electrical was a complete mess. The good news for today is that we got everything running and made her maiden voyage of this century! Left the garage and returned under her own power! Prior to the voyage, we re-wired everything and it was all working perfect. Somewhere within our 1/4 mile trip around the block the lights and horn all stopped working. Using my multimeter I isolated the problem down to the "black box". It is a black box mounted on the firewall. I'm new to old cars but the best I can tell it is the antique version of a circuit breaker. Please see the pics below and let me know what you think. It has two posts on it. One labeled "IGN" and the other "FLD". The "IGN" is receiving 12v from the coil. The "FLD" is supplying 12v to the switch on the steering column. Prior to our trip it was reading 12v in and 12v out. After the trip it now reads 12v in and about 3.8v out. The backside has two "ceramic spring" contraptions in a V shape. For kicks and giggles I bypassed this box for a couple seconds and all of the lights and horn worked properly. I'm hoping I can replace this with a modern circuit breaker that can handle the load? Please let me know. I really appreciate your help. Thanks, Matt
1929 Model A 1992 Galant VR4 474/1000 2007 Prius 54mpg |
01-05-2013, 08:49 PM | #2 |
Re: What is this and why did it stop working? (Electrical Problem)
That looks like an old Chrysler voltage regulator, see the link.
http://www.napaonline.com/Catalog/Ca...R32_0354837625 Bob |
01-05-2013, 08:54 PM | #3 |
It looks like a regulator for an early Chrysler Product alternator??? Possibly, someone may have used it as a makeshift relay??? I would consider removing it & just join the wires together. WARNING this is just my THOUGHTS!!
It's hard when I can't see/touch the system. Bill W.
01-05-2013, 09:28 PM | #4 |
Is it a resistor on the coil to run the car 12 volts? Has it been converted to 12v??
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
01-05-2013, 10:44 PM | #5 |
Looks like it may have been used as a voltage reducer, maybe the coil part of the "black box" was providing the "voltage dropping resistor". The only thing that is not easy to convert to 12 volts is the horn, so if it was me I would remove the old box, install a voltage droping resistor in line with the horn (in the wire that runs to the horn) and run everything at 12 volts. If you still have 6 volt light bulbs replace them with 12 volt ones, make sure you have a 12 volt coil, and you will be good to go, no more old parts being "rigged" to do something they were never designed to do.
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
01-05-2013, 10:46 PM | #6 |
01-05-2013, 11:03 PM | #7 | |
An ignition ballast resistor is a special type of resistor, called a PTC, or positive temperature coefficient resistor. When it is cold, the resistance is less, permitting more current to flow through the coil, giving a hotter spark. In about 10-15 minutes, it gets very hot and the resistance goes up about 50%. That reduces excessive current pitting of the points. In all cases a coil with an external PTC resistor is far superior to a so-called 12V coil with no external balast. Those coils do not produce a hotter spark when cold, and physically run at a higher final temperature, resulting in shorter life. |
01-05-2013, 11:20 PM | #8 | |
According to this Wiki article ( http://en.wikipedia.org/wiki/Voltage_drop )the Voltage drop is calculated differently depending on if the Voltage is AC or DC.
Wanted: Simmons Super Power Head Craig Likon 1931 150B Last edited by ctlikon0712; 01-06-2013 at 03:29 AM. |
01-06-2013, 12:32 AM | #9 |
Thank you for the replies. The Model A was converted to a 12v system before we bought it. It has an alternator and 12 volt coil. It also has 12v light bulbs. It starts and runs good, but the previous owner never finished any of the wiring to the lights or horns. I also doubt that the alternator was ever hooked up. I'm pretty sure it has only been driven about 10 miles in the last 30 years and it was done with no lights and on battery power only. The way the wiring was when we bought it, it would not be possible to use any accessory.
The NAPA link above is exactly the same part. This is definatley a voltage regulator. Thank you for the link. Now I have to research to determine if I need to keep it for the alternator and whether or not I can bypass this for the lights and horn. Thank you.
01-06-2013, 03:19 AM | #10 |
Don't get confused by some of the posts above. It makes no difference if you are using an alt or a generator, both output "DC". And yes you will get a different reading from one side of a resistor to another when current is flowing.
01-06-2013, 03:22 AM | #11 | |
Normally the regulator IGN terminal gets 12V via the ignition switch, and the "FLD" terminal gets connected via a wire to one (either) of the field terminals on an alternator. The other field terminal on the alternator gets connected via a wire to ground.
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 01-06-2013 at 03:35 AM. |
01-06-2013, 03:31 AM | #12 |
Gosh, your right Mike. I don't know what I was thinking. I edited that out.
Thanks
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
01-06-2013, 03:36 AM | #13 |
Just a tip, those simple & inexpensive Chrysler regulators can be used on many externally regulated alternators. I used many on older Volvos, with a Bosch alternator to PEP up the system. The Bosch regulator was only rated at 12.5 to 13 volts, too LOW! The Chrysler regulator was rated at 14 to 14.2 volts, much better at 1/4 the cost! Bill W.
01-06-2013, 03:47 AM | #14 |
Not a problem I've done it many times myself!!
01-06-2013, 09:17 AM | #15 |
Thank you very much guys. I don't know what type of alternator is on there but after further inspection, one of the three posts is labeled "FLD". The other "BAT" and the last is "GRD". I think I need to run the regulator "FLD" post to the alternator "FLD" post and then use a different source for the 12v lead to the light/horn switch. I feel like I need to put a fuse in the 12v source. This vehicle currently does not have any fuses. What do you guys do to resolve the fuse situation? Thank you so much for your help. -Matt
01-06-2013, 09:40 AM | #16 |
Hi Matt, In for a dime, in for a dollar... I recommend to you that you get a glass fuse block of 4 to 6 glass buss fuses. With your 12 volt system, you can split up your electricals to fuse alternator, ignition, front lighting, rear lighting and horn, and accessories. Get a couple of 12 volt relays to wire to the lighting switch to activate high and low beams, direct 12volt in and out to the headlights. Very simple, and you can get cloth-wrapped wire and fabric wiring loom tubing to make the whole thing look authentic. It'll take you a day and a half to do if you have all the parts. Happy motoring!
Chris |
01-06-2013, 10:31 AM | #17 |
Matt, I went back and looked at the wiring pictures you posted a few weeks ago. YIKES! I'm still having tremors. Based on your pictures (re-posted below) I STRONGLY suggest you get a complete, new authentic-looking wiring harness from Brattons or Snyders.
Don't further jury-rig stuff. Since you do not have turn signals you can get a complete body/engine harness with a signal-stat 900 lever already correctly wired in. The wiring harness through the firewall to the starter lug is a separate item, get that too. You also need an unbroken terminal box with lid before you start running any wires through it. Get the fuse holder that connects to the starter switch and put a 25A fuse in it. That single fuse will protect everything except the heavy battery cables. The Chrysler alternator you have requires an external field regulator. The original Chrysler electro-mechanical jobs were very unstable and unreliable. About '72 Chrysler went to a 'flat-pack' electronic external regulator which can be used (With even more wiring mods!) but you may want to consider a different alternator with an internal voltage regulator to simplify things. This is Matt's dilemma: |
01-06-2013, 10:42 AM | #18 |
Guess I missed those pictures. YES GET A NEW WIRING HARNESS IMMEDIATELY!
Oklahoma City Model A Restorers Group. |
01-06-2013, 11:03 AM | #19 |
WTF?!!??
My gut reaction is to rip all that stuff out and rewire it back to standard. One of the things I hated about my Town Sedan was when I found out the hard way that a previous owner had changed the wiring around (made for some real fun when I had to troubleshoot a short that developed) |
01-06-2013, 11:44 AM | #20 |
I'd agree with the fellas regarding changing the wiring. The Alternator you have appears to be an old style Y-wound [good alternators]. The 'thing-a-ma-jig' on the firewall that went bad is a voltage regulator. Just jump the 2 terminals and see what the ammeter says with the engine running at a fast idle, it should then show a charge. All the regulator does is control field current. I see you already have a ballast resistor for the coil[ the little white 'gizmo']. When installing a fuse, most fellas just install one off the main supply at the starter switch. But, as said, you certainly could use some new wiring.
01-06-2013, 12:07 PM | #21 |
Wow what a thread. I do not see an ignition wire to the VR. An early B circuit Chrys. alt has to be the worse choice for a retrofit. They put very little out at idle and the pulley is difficult to change. As well wider belt options are very limited.
That alt has many variations and most are mixture of those variants. Rotors are identical in appearance but pull different amperage as well as the rotor "bobbin" height is all over the board. These difference tho' subtle will make changes as to how the alt works especially at low rpm. Otherwise not a bad unit....in 1963. Bill W you are right about this VR and Volvos. It is easier to increase the voltage on the existing VR and if a Volvo with an isolation diode (or SEV) the Chrys. VR is set to low. You would have to reset it, + .7V (15.2V). |
01-06-2013, 01:15 PM | #22 | |
AND a FIRE EXTINGUISHER to KEEP CLOSE!!! especially if you start it like that!!
01-06-2013, 02:28 PM | #23 | |
Strangely enough, I don't remember ever havin' to reset a Chrysler regulator used on a Volvo as it seemed to maintain the system O.K.at 14.2 to 14.5 volts & they never seemed to fail. Isolation Diode would also cause alt light to glow slightly at night under a heavy electrical load because of uneven voltage to each side of the bulb. I corrected this with a 10 OHM resistor on the higher side. Are you an old Volvo Tech also? Bill W.
01-06-2013, 03:22 PM | #24 |
I'm a big fan of putting everything back to original.It just keeps it simple,and if you're electricly challenged at least if it is original anybody familiar with A's can help you with it without having to decipher what the builder did to make it work.12 volts is fine if you have a use for it,but if you don't there is just no reason to complicate things.It just doesn't get any simpler than what the car came with.That wiring makes a plate of spaghetti look organized.It is a fire waiting to wake up and go to work.I do remember those alternators as being problematic when I worked on cars back in the 70's.I believe that was one of the early ones that couldn't tolerate any mistakes.Touch the wrong wire to the wrong spot and it was toast.An original generator and a $50.wiring harness will simplify your life.
01-06-2013, 04:34 PM | #25 |
Well, when it comes to putting everything back as Ford intended, I agree. Its simple and it works.
01-06-2013, 06:26 PM | #26 |
01-06-2013, 09:43 PM | #27 |
I am using a Ford electronic regulator to control a Chrysler Alternator and it works very well. Fld term on regulator is connected to Fld term on Alt, Ign term on Reg is connected to Ign Switch and the Bat term on Reg is connected to the Bat term on the starter switch, which tells the regulator the battery voltage and then the regulator responds to the need of the battery. The Chrysler regulator does not have the Bat term and depends on sensing battery voltage thru the ign switch, which can be problematic, especially if the ign switch has resistance across the contacts, which will cause the ammeter to swing and jump.
01-07-2013, 02:55 AM | #28 |
If it were just the alt/reg I would say repair it, but looking at your pictures, rip it all out and start over simple cheap easy to do. If you want to still use that alt, then get another regulator and wire it like in the above posts. You can get "old style" wire by the foot to wire the regulator from Sacramento Vintage Rord along with the Wiring harnesses.
01-19-2013, 11:52 PM | #29 |
Hello everyone, I'm just following up on this thread. I have all of the wiring finished and working properly. It's not original or pretty, but everything is safe, fused and working well. Thanks for all of your help.
01-20-2013, 06:16 AM | #30 |
Great to hear, now you two go enjoy that truck!
01-20-2013, 09:24 AM | #31 |
rewire the correct way ...............
V4f |
01-20-2013, 09:44 AM | #32 |
I was amazed when I wired mine, to do it original cost less than buying the wire and connectors from the hardware store.
1929 Model A Barn find. California car, just a few more parts to find. Interior, steering box (rebuild), and I am sure much more! |
01-20-2013, 01:03 PM | #33 |
Don't mean to be a party pooper but it still looks like hell
safe?? if you say so disconnect your battery or install a disconnect switch when not in use especially if its parked nearby your house. Last edited by Mitch//pa; 01-20-2013 at 01:25 PM. |
