Old 04-03-2018, 08:33 AM   #1
jhowes
Default Wrist pins
I am wondering how the shade tree mechanic tests the wrist pins ( piston pins) If the engine is still in the car and the pan is removed
WRIST PINS OR PISTON PINS ARE SUPPOSED TO HAVE A VERY CLOSE TOLERANCE, SO HOW DOES THE SHADE TREE MECHANIC TEST THAT TOLERANCE??? THE PAN IS OFF THE ENGINE AND THE ENGINE IS STILL IN THE CAR?? I HAD A MACHINE SHOP DO MY PINS ON ANOTHER ENGINE AND THEY SEEMED TO BE VERY TIGHT BUT HOW TO CHECK THIS ON MY OWN IS THE PROBLEM. JACK
jhowes is offline   Reply With Quote
Old 04-03-2018, 08:52 AM   #2
100IH
Default Re: Wrist pins
First there 2 fits to look at, The fit of the pin in the piston and the fit of the pin in the rod bushing. For my money, the rod caps should be removed and the piston assy. needs to come out. At that point it's a feel thing. What does .0006 - .001 feel like. These are general ballpark numbers but are so slight that measuring ID & OD won't be practical unless you have your Sunnen pin fitting hone with the gauges in the garage.
100IH is offline   Reply With Quote
Old 04-03-2018, 09:32 AM   #3
jhowes
100IH, What does .0006-.001 feel like? I suspect "feels like no movement at all". So there is no way for the shade-tree mechanic to do this. Jack
Old 04-03-2018, 09:35 AM   #4
jhowes
Sorry about the double post. Jack
Old 04-03-2018, 09:58 AM   #5
100IH
No sense of wobble. sideways movement. pin to rod and pin to piston. A fair amount of drag when sliding in or out with light oil. A written description not as good as feeling the real thing and not as good as using the tools that are on the hone.
Old 04-03-2018, 10:51 AM   #6
40 Deluxe
The 'feel' of the fit varies with the individual. There is a "palm fit" and a "thumb fit", for example. Next, what is the temperature of the piston when you're checking it? Are you reaming or honing the pin bushings? Lots of variables! As 100IH says, best to let a machine shop measure if you have the slightest doubt.
Old 04-03-2018, 11:13 AM   #7
George Miller
George Miller's Avatar
You would have to take them out. The best way is lessen to your engine before you tear it apart. If it has noise find out which cylinder. Then by sound at different rpms you can tell what it is. I never tear a engine apart with wrong noise going on tell I know what it is.
George Miller is offline   Reply With Quote
Old 04-03-2018, 01:08 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
By rocking the crankshaft and looking for movement, also a finger spanning both surfaces can feel slight movement--- sometimes even watching the oil squish out-- if it squirts out the side it's most likely too loose
Old 04-03-2018, 01:30 PM   #9
Kahuna
Kahuna's Avatar
With piston & rod removed, when piston is held horizontal, rod should drop slowly.
Kahuna is offline   Reply With Quote
