07-13-2012, 04:25 PM | #1 |
Intake Manifold
I'm running with a 37 block, 36 heads and an aluminum intake manifold. I noticed that 3 small cracks have developed around the bolt hole where the generator is mounted. Someone must have tightened the generator bolt too tight. I would think it would be a disaster if the generator would let loose or shouldn't I worry about it? Please advise: Can I have the manifold welded or should I look for a replacement? Does anyone know where I can find one and does it matter if it is cast iron rather than aluminum? Also, what years fit a 37 block? Thanks in advance, I couldn't continue in this hobby without you folks....DK
07-13-2012, 05:09 PM | #2 |
Re: Intake Manifold
any manifold up to 48 fits. they are very cheap. I paid $23 + $28 postage for a later model cast iron for my 37 motor. I replaced mine to install an alternator.
07-13-2012, 06:56 PM | #3 |
Re: Intake Manifold
If you change to a CI one you will have to change the FP push rod to 1 thats 8 7/8 long.. I would have the alum. one welded. ken ct omo.
07-13-2012, 10:05 PM | #4 |
Re: Intake Manifold
If you live where it gets up near 90 degrees get a CI one. The aluminum gets hotter and is closer to the fuel pump causing the fuel pump to get very hot and boil the new gas. G.M.
www.fordcollector.com |
07-18-2012, 06:43 AM | #5 |
Re: Intake Manifold
GM, thanks for your info on the intake manifold. Wouldn't the cast iron hold up better having the generator and fan on top of it ? Is the CI the very same shape as the Alum. Thanks for your help. I've found some sources but having trouble communicating, it's my first time on this...DK
07-18-2012, 12:23 PM | #6 |
Re: Intake Manifold
Alan |
07-18-2012, 01:55 PM | #7 |
Re: Intake Manifold
Darrell, here is a comparison between the cast iron and the aluminum intakes. The cast iron intake in the pic is a 46-48 intake and is the same heigth in front as the 39 that was on the engine I am working on. The aluminum intake was on a 37 block that was in my 36. As Ken mentioned, the cast iron intake requires a longer fuel pump push rod and also a longer oil pan vent tube (tube under the intake at rear where the fuel pump bolts on). Joblot has this one: part # 48-6756-A
07-18-2012, 02:13 PM | #8 |
Re: Intake Manifold
i seen a generator let go on a 41 convert it did a lot of damage ,distroyed radiator,fan,a real mess,do whatever it takes to get it right...
07-19-2012, 03:44 AM | #9 | |
Re: Intake Manifold
Alan |
