Old 03-03-2020, 03:37 PM   #1
Paul Bennett
Default Polishing head fins
I see pretty flathead engines with polished aluminum head fins and some with satin finish fins. What is a typical cost for polishing and is there a downside in the future? I imagine one has to wipe dust and oil off every so often whether they are polished or not.
Paul Bennett is offline   Reply With Quote
Old 03-03-2020, 08:51 PM   #2
Tinker
Tinker's Avatar
Default Re: Polishing head fins
Where you at? There is a guy up here that polishes anything. Fairly cheap.
Old 03-04-2020, 09:16 PM   #3
paul2748
paul2748's Avatar
Name ???? Web site ????
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-05-2020, 01:00 AM   #4
drolston
drolston's Avatar
I bought a range of sand paper and aluminum buffing compounds from Eastwood, and a hand held rotary tool, and did the heads and intake manifold myself. It is kind of fun to do. Took maybe 20 hours. I just did the sides of the heads and the top edges of the fins, not the insides between the fins. Results were good, but not brilliant. Pictures show progress on the intake from stock Offenhauser to 80 grit to 240 grit to polishing compounds and anti-corrosion coating.
Old 03-06-2020, 12:10 AM   #5
RalphM
RalphM's Avatar
It’s not hard to do, just time consuming. Get a dremmel or like tool. This will get between the fins.
Here are some hub caps I just did. We’re as cast aluminum finish to start.
Well I was going to post pictures, but once again they won’t load.
RalphM is offline   Reply With Quote
Old 03-06-2020, 03:30 PM   #6
Tinker
Tinker's Avatar
It's a local guy Northern MN, fast eddie. No website or anything. Not sure he ships.
Old 03-06-2020, 04:21 PM   #7
chiefdave
chiefdave's Avatar
The easiest way to refurbish a set of stained and tarnished heads is a can of engine paint. Then progressively finer grit discs on an orbital sander followed by polishing compound if you wish to polish the fins.
chiefdave is offline   Reply With Quote
Old 03-06-2020, 05:47 PM   #8
tubman
tubman's Avatar
Can you help us get in touch with him? Being up in northern Minnesota, he must be looking for business. Since I'm in the Brainerd area, he would be convenient to me and I need some stuff done.
Phone number?, address?, you must have something.
Old 03-06-2020, 08:31 PM   #9
hardtimes
hardtimes's Avatar
Hey Paul,
I am fortunate to have/use a guy about three mi away for my alum polish needs. He has a shop and does government stuff as his main stay $.
However, he will polish stuff and isn't cheap. He looks over what you have and will price it according to how much time it will take to do (ruff/dirty/oily..etc).
His guys do a GREAT JOB even to show polish. When you factor in shipping, insurance and whatever, would be best to locate someone near by to save.
To get best job, IMO, you should start out with CLEAN /new unused alum.
But after you get back and use parts, they will oxidize/dirt/oil, etc, so how clean you want to keep such stuff is a personal decision. I have learned tho, that a guy can have newly polished alum/other parts ...coated with a process that protects the shine and prevents oxidation. Kinda like a clear coating but maybe different ?
I had this done on this pictured pieces. You can see the quality of his work here...if comes thru: can give info of polisher on req..
Old 03-06-2020, 08:37 PM   #10
Tinker
Tinker's Avatar
I'll pm you.
