Old 04-10-2018, 08:46 PM   #1
Bud
Bud's Avatar
Default Model B Transmission & Adapter Kit
City: Fort Loramie
State: OH
Price: in ad
Pictured here is my 1932 Model B transmission and the adapter kit parts I used when I had it in my Model A Town Sedan. I had used the case and the adapter kit in my car. I had not used the 1932 gears--these are the original gears that were in this case when I got it. The gears are in very good condition. I am also including an NOS 1932 Cluster gear with this package as well. What you see in the photos is the transmission (housing and gears), the extra NOS Cluster gear, the pedal shaft adapter, the emergency brake bracket, the wishbone bracket, the throwout shaft and the Model B half flywheel housing. Not included is the shifter tower, the main drive gear bearing retainer, the rear bearing retainer, original clutch throwout shaft, throwout hub, the throwout fork and the pin for the trans and reverse idler shaft. The case and gears are in very good condition. The original transmission inspection cover is included with the lubrication fitting. Also included but not pictured are the special motor mounts I had made to fit this conversion. Expect to replace some or all the bearings plus you will need a gasket kit. I am asking $500 for everything. You will have to pick up this item because I would not have any means to ship it. Contact me on Fordbarn for questions. This is advertized in the Model A Forum as well.
Bud is offline   Reply With Quote
Old 04-10-2018, 08:50 PM   #2
Bud
Bud's Avatar
Default Re: Model B Transmission & Adapter Kit
Additional photos of the NOS cluster gear. The transmission already has a good cluster gear. Not pictured are the custom motor mounts (NOT Float-a-Motor mounts) that I had made. These motor mounts are Model A motor mounts with the ends cut off and a 1" thick steel plate welded on to mate with the B flywheel housing. I had them in my car and they worked fine.
Old 12-13-2018, 08:34 PM   #3
Bud
Bud's Avatar
Adapters and Cluster Gear are SOLD. I still have the transmission, gears and FW housing if anyone is interested. Please make an offer. Pickup only, too heavy to ship.
Thanks.
