Old 11-20-2012, 02:02 PM   #1
Chris
Chris's Avatar
Default What is the story with this flathead block? Raised intake area
I recently bought this engine, I was told it is a 1941. I took the intake off and noticed the raised intake area. I was told this could be Mercury?? Can anyone shed any light on what is it, or if it is anything special?
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 11-20-2012, 02:04 PM   #2
Bruce Lancaster
Default Re: What is the story with this flathead block? Raised intake area
'41-42-wartime engine. Referred to as raised, but actually the shoulders are lowered!
Lift off a head and look at center vertical row of water passages: If lower 2 are trapezoidal it is a 221, if only lowest is trapezoidal and others round it is a 239 Mer/truck.
Bruce Lancaster is offline   Reply With Quote
Old 11-20-2012, 04:29 PM   #3
Chris
Chris's Avatar
Thanks Bruce! Trying to get the heads off now, fingers crossed it's a 239!!
Old 11-20-2012, 04:43 PM   #4
Bruce Lancaster
A 221 can go to 239 bore with pretty good safety but not a whole lot farther.
If it is an original 239, look into the trapezoidal hole where it approaches a cylinder... the wall at least at the top there is almost shockingly thick!
Old 11-20-2012, 04:44 PM   #5
Fe26
Keep us posted...
Fe26 is offline   Reply With Quote
Old 11-20-2012, 04:50 PM   #6
Mike in Mass
Mike in Mass's Avatar
you want this ! ! ! I busted two studs betting my heads off , drilled an retapped ,no biggy . I allso heated up a couple bolts that would not budge . ,not cherry red, just to get things movin its like hittin the lottery if you have the raised deck its a merc 9 out of 10 times. I have heard stories of one without the other. good luck !
Mike in Mass is offline   Reply With Quote
Old 11-20-2012, 04:51 PM   #7
Chris
Chris's Avatar
Originally Posted by Fe26 View Post
Keep us posted...
I will...heads will not budge and I'm trying to be really gentle with em and not dig between them and the deck. I've been soaking the studs with PB-blaster since Saturday, may hook a battery to it and wing it over...see if that pops em up.
Old 11-20-2012, 05:31 PM   #8
jack in san diego
Try hooking up a battery and turn the engine over with plugs in, it should pop uf free. If not, use lots of penetrating oil and let it set and fume overnight, then try again. Good luck
jack in san diego is offline   Reply With Quote
Old 11-20-2012, 05:45 PM   #9
B-O-B
B-O-B's Avatar
Get some wax & melt it on the studs after you heat them up.
B-O-B is offline   Reply With Quote
Old 11-20-2012, 07:15 PM   #10
Ball and Chain
Ball and Chain's Avatar
helmet dist is 41?
crab is 42?
I have one of these motors too, is there anyway to tell without pulling a head?
Throttle Benders
Est. 1949
Ball and Chain is offline   Reply With Quote
Old 11-20-2012, 08:34 PM   #11
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I've had alot of those blocks come in my shop and I've never seen a 239, every one I've had were 3-1/16 = 221ci. I've never notice the water holes. I always remove the sleeves and bore another .045 to 3-3/16=239ci. It makes a seat of the pants differtance useing the A heads. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 11-23-2012, 03:51 PM   #12
Ball and Chain
black friday bump?
Throttle Benders
Est. 1949
Old 11-29-2012, 01:39 AM   #13
Chris
Chris's Avatar
Looks like it's a 221 huh? I gotta get an inside micrometer to be certain...
Old 11-29-2012, 06:18 AM   #14
Henry/Kokomo
Henry/Kokomo's Avatar
How'd you finally get the head off? Looks like one down, one to go.
Henry/Kokomo is offline   Reply With Quote
Old 11-29-2012, 11:50 AM   #15
Chris
Chris's Avatar
I measured the bore this morning with a caliper and it's right at 3 3/16, so maybe someone bored it to 239? I'll get an inside micrometer and find out exactly what it is!
Old 11-29-2012, 11:50 AM   #16
Chris
Chris's Avatar
Made a head puller. Still gave me a lot of grief but I finally wrestled it off. Now I gotta do the other side
Old 11-29-2012, 12:34 PM   #17
Bruce Lancaster
The water hole configuration is 221 type. Next check...look into the lower trapezoid hole at the third cylinder: If block was a 239, the outer wall would nearly reach the hole, showing absolutely massive thickness at that point. If 221, thickness would just look kinda normal..
Old 11-29-2012, 03:42 PM   #18
Chris
Chris's Avatar
Bruce,
Looks like a regular one I guess. I also checked piston size and they are standard. I'm really leaning twards a 221 that has been punched to 239
Old 11-29-2012, 04:18 PM   #19
Bassman/NZ
Bassman/NZ's Avatar
Nothing wrong with a 221 bumped to 239.
Bassman/NZ is offline   Reply With Quote
Old 11-29-2012, 04:35 PM   #20
Walt Dupont--Me.
I think you'll find that was a sleeved engine from the factory, the sleeves were .040 thick. The sleeves have been removed and the block bored another .045 to 3-3/16 std. I've done alot of those. with the 221 heads and the bigger bore you can really feel the differance in the low end torque. Walt
