Old 12-02-2014, 06:00 AM   #1
flathead 53
Default reverse eye spring
thinking about getting posie reverse eye front spring for my 40 deluxe coupe, any problem keeping original shocks,with lowered spring? thanks
flathead 53 is offline   Reply With Quote
Old 12-02-2014, 09:33 AM   #2
TJ
TJ's Avatar
Default Re: reverse eye spring
Shouldn't be a problem. You may have the trim(shorten) the rubber snubbers on the frame over the axle. Why not use your existing spring and just buy a reversed eye main leaf?
Old 12-02-2014, 09:51 AM   #3
Vic Piano
Vic Piano's Avatar
I have a set of the Posies reverse eye springs on our '47 Ford Convertible with the OEM shocks, no problems however, it is a good idea to trim the rubber bumpers as mentioned.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 12-02-2014, 09:54 AM   #4
Seth Swoboda
Seth Swoboda's Avatar
No problem. I'm running this set up on a '39 pickup. It only lowers the front about an inch. I am running the stock shocks and 6.50x16 tires. In fact the reverse eye spring is barely noticable.
Old 12-02-2014, 10:45 AM   #5
19Fordy
19Fordy's Avatar
Here's a photo of my 40 when I installed ONLY the Posie reversed eye front spring on the stock front end.. It lowers the car about 1 inch and maybe a 1/2 inch more over time. This photo was taken right after the install. I did not have to trim the rubber axle bump stops.You can see the tiny amount of "rake". Click on photo to enlarge.
Old 12-02-2014, 05:50 PM   #6
El Rat
I use the "flat nosed" bumbers with no problems on my 38. Stock shocks. Your 40 should already have them...
El Rat is offline   Reply With Quote
Old 12-02-2014, 06:47 PM   #7
41LjH
41LjH's Avatar
I used a reverse spring on my 41 pickup. I talked to Posie rep before I ordered. He stressed it lowers the advertised amount based on the ORIGINAL height. Because my truck is 73 years old settling of the stock spring has occured. Therefore I should not expect the full advertised drop. The spring reduced the relationship between the tie rod and the frame so I installed dropped tie rod ends to clear the oil pan. I can't comment on the shocks because I went to tube shocks and removed the originals.
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
Old 12-02-2014, 08:28 PM   #8
jack in san diego
I put a posies type complete front spring in my 40 pickup, it lowered it about 2 1/2 inches. I purchased it from Speedway, cheaper. I had to shorten my shock absorber links to as short as possible. I cut them and welded back together. I haven't heard if anyone else had this problem. The rake was perfect. Jack
jack in san diego is offline   Reply With Quote
