Old 03-14-2023, 07:56 AM   #1
Merc Cruzer
Merc Cruzer's Avatar
Default 1CM crankshaft
Does anyone have pictures of a 1CM crankshaft?
Thank you.
Merc Cruzer is offline   Reply With Quote
Old 03-14-2023, 09:23 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: 1CM crankshaft
This photo set is from the HAMB on a for sale add. It's not real clean but the 1CM is visible.
https://www.jalopyjournal.com/forum/...troke.1112761/
The major change was the larger bore size in the rear flange to accommodate the automatic transmission torque converter. Other wise they are basically the same and interchangeable.
Old 03-14-2023, 09:51 AM   #3
Merc Cruzer
rotorwrench;,
Thank you for the response. This us what I get for posting too early in the morning. I wrote crankshaft when I should have written camshaft. I will start a new post.
Thanks again.
