12-28-2023, 10:58 AM | #1 |
Front fender welting 32 tudor
Does the welting under the front fender start at the firewall and run all the way to the front of the frame? If it does, do you cut out for the rivets on the front cross member?
12-28-2023, 01:09 PM | #2 |
Re: Front fender welting 32 tudor
Those rivites are usually flush type? Newc
12-28-2023, 02:19 PM | #3 |
Are you referring to the beaded fender welting on the side of the frame forward of the running board or the flat 1/16" x 2" body to frame welting? If the latter, then yes, all the way to front end of the frame.
As Newc notes, your front fenders are not going to fit correctly if the rivets for the front cross member are not flush with the top of the frame rail.. |
12-29-2023, 09:29 AM | #4 |
Maybe the front crossmember was replaced because it is attached to the frame with low profile square head bolts. I have attached a picture. I could grind them down if they are suppose to be flush.
12-29-2023, 11:43 AM | #5 |
12-29-2023, 03:02 PM | #6 |
12-29-2023, 04:37 PM | #7 |
Good advice, and thank you for the knowledge that these should be countersunk rivets. I would never have known the difference if it weren’t for your well written response to my questions. I will take off one of the bolts and see if I can find countersunk bolts that will work.
12-29-2023, 05:07 PM | #8 |
You're welcome.
