Old 06-16-2019, 08:12 AM   #1
bo8109b
bo8109b's Avatar
Default Carburetor accelerator pump
Should a new accelerator pump "leather" be oiled prior to installation? Carl
bo8109b is offline   Reply With Quote
Old 06-16-2019, 09:23 AM   #2
Russ/40
Russ/40's Avatar
Default Re: Carburetor accelerator pump
Any oil applied will be gone in a moment when gas gets there. It won't hurt anything if you do though.
Old 06-16-2019, 09:24 AM   #3
ford38v8
ford38v8's Avatar
Yes
Alan
Old 06-16-2019, 11:28 AM   #4
drolston
drolston's Avatar
I just installed brand new accelerator pumps with leather skirts. I was worried that they fit too loose. Within a few minutes they had swollen up to form a good seal, and they pump perfectly. if you subsequently remove them they are a bear to get back in with the skirts down straight. For a Stromberg 97, it is best to separate the plunger from the carburetor top to install them, and then wiggle the shaft through the hole in the top, without pulling the plunger up too high. If you mess it up they will bind and not pump right.
But to answer your question directly, oil is not needed, but can' hurt.
