Old 07-08-2015, 08:47 PM   #1
TK in LA
TK in LA's Avatar
Default Piston installation
OK Barner's here we go. I'm in the process of re-ringing a '29 motor. On tear down I noticed all the pistons have the arrow to the rear which is normally to the front. On removal, the rod is in the correct orientation for the slinger and the expansion slot is away from the cam in this configuration, that is all but one. On it, the arrow was facing to the rear like the others but the slot was on the cam side. Where do I go from here? Reverse the pistons so the arrow is to the front and the expansion slot is towards the cam or leave it alone. What about the odd piston?
Thanks for any thoughts you may have on this. Always fun and interesting!
TK in LA is offline   Reply With Quote
Old 07-09-2015, 10:37 AM   #2
katy
katy's Avatar
Default Re: Piston installation
IMHO I would put the pistons back in the way they came out.
Your mileage may vary.
Old 07-09-2015, 10:51 AM   #3
Jim Brierley
I would reverse all but the odd piston. The expansion slot should be away from the thrust (power) side.
Old 07-09-2015, 07:43 PM   #4
TK in LA
TK in LA's Avatar
Thanks Katy and Jim for your input. After more research I'm going with Jim's reply. Though in the long run it probably won't make a large difference, at least I know it will be the best it can be to start with. Thanks again for taking the time to respond.
Old 07-10-2015, 02:43 AM   #5
Barber31
Barber31's Avatar
I would also say to replace them as they were. If you're doing a re ring job then it obviously has some miles on it and that means the parts are worn into each other already. Switching things up might cause more problems down the road. I would at least call a engine rebuilder to get their opinion.
Barber31 is offline   Reply With Quote
Old 07-10-2015, 05:36 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
Jim Brierley is an engine rebuilder.
Old 07-10-2015, 09:39 AM   #7
Barber31
Barber31's Avatar
Haha. Well that settles it then!
Old 07-10-2015, 11:36 AM   #8
Jim Brierley
The items where wear pattern is important are the rings, which you are replacing.
Old 07-10-2015, 04:06 PM   #9
TK in LA
TK in LA's Avatar
Correct Jim. Who ever worked on the motor previously did a lot of strange things. My main concern that started this was the excessive oil in two of the cylinders and lower compression. Looks like they had a couple of pistons with the rings almost in line and the oil rings were all the single ring type. I've gone to the Grant rings with the three piece oil ring. The motor isn't that great but this should improve over it's previous condition. Thanks again!
Old 07-11-2015, 02:13 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Do you have any pictures of the pistons?
The cam side is the thrust side, so the slots should be against the driver's side (left side). Also look at the skirts and see if the thrust side doesn't have more contact area, as many pistons do.
Old 05-21-2020, 07:56 PM   #11
Glenn Thoreson
Glenn Thoreson's Avatar
An old thread for sure but it solved my problem. I'm currently doing a ring and vavlve job on my hillbillt parade jalopy. All the piston skirt slots faced the cam but number one. It was facing the opposite. Having not remembered which way was right, my brain was boiling over. So, I decided to ask you guys. Problem solved! Many thanks!
Glenn in Wyoming
Glenn Thoreson is offline   Reply With Quote
Old 05-23-2020, 09:09 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
Confusion re thrust side of a cylinder?? I believe the following to be the correct logic.
In the Model "A," the cylinders are offset 0.125 to the left (driver's side) of the crankshaft's rotational axis. So the thrust side of a cylinder is its left side. As such, the expansion slot in a piston should be to the left (driver's side) of the engine.
Bob Bidonde
Old 05-23-2020, 12:41 PM   #13
Jim Brierley
The thrust is on the left side. With the piston going downward on the power stroke, the rod is angled to the right, putting the thrust on the left, the cam side, as Tom stated.
