Old 05-15-2020, 12:37 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Sharp dressed helmet ????
This made me you tube the tune " Sharp Dressed Man" bu ZZ top . This would be the ultimate sharp dressed helmet ... all the good stuff , 11A advance weights , small cam dual hd echlin points, new load tested condensor, gaskets and proper wire set .......polished case (Andy Tantes )
Ran on tester and adjusted then ran 5000 plus for a few minutes and rechecked ......
Cant for the life of me figure why you would ever run anything else ??? And this customer has the tubes as well ,
Gotta be the look with all the performance you ever need .....
And the brown plastic liesure suit ????
listen to the tunes :
https://www.youtube.com/watch?v=7wRHBLwpASw
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 05-15-2020, 12:52 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Sharp dressed helmet ????
Old 05-15-2020, 01:33 PM   #3
FlatheadTed
FlatheadTed's Avatar
Nice Job Bubba, I like the diver there's a bit of the Botch in there because of Emel .I got a call out Frid night to fix one
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 05-15-2020, 01:49 PM   #4
Zeke3
Zeke3's Avatar
Great looking distributor, that would look great on my 21 stud. Have to think about having the case polished.
Zeke3 is offline   Reply With Quote
Old 05-15-2020, 02:02 PM   #5
tubman
tubman's Avatar
The sticker on the front provides a proper finishing touch!
Old 05-15-2020, 02:05 PM   #6
BUBBAS IGNITION
the polish dude .........
https://www.facebook.com/aluminumpolishing
[email protected]
Old 05-15-2020, 02:14 PM   #7
Ggmac
Excellent !
Old 05-15-2020, 02:37 PM   #8
41panelmark
41panelmark's Avatar
Very nice...
41panelmark is offline   Reply With Quote
Old 05-15-2020, 07:08 PM   #9
grumppyoldman
grumppyoldman's Avatar
You should have polished mine like that, looks sharp. Al
grumppyoldman is offline   Reply With Quote
Old 05-17-2020, 08:24 PM   #10
MrModelT
MrModelT's Avatar
That is downright GORGEOUS...������
MrModelT
1926 Model T Roadster
http://www.jalopyjournal.com/forum/s...d.php?t=308741
MrModelT is offline   Reply With Quote
Old 05-17-2020, 09:11 PM   #11
26 lakes
Thought I would show some of Jim's outstanding workmanship. This V12 was converted to V8 . Coil was redone by Skip Haney. It will be used on a 1941 Mercury flathead. This is going in a pre war lakester. Should have fire going through it by the end of the year.
26 lakes is offline   Reply With Quote
Old 05-17-2020, 09:15 PM   #12
petehoovie
petehoovie's Avatar
