10-31-2011, 04:42 AM | #1 |
Banger Compression
Hello. Last night, Dad and I took compression readings on a newly acquired 1929 A and found to be low at 25 lbs. Cylinder 3 had none. So, off came the head and we found a stuck valve. We spun it over to get it free, but I am not sure on the others.
It appears that someone may have rebuilt this before because there are markings on the tops of the pistons. there are 4 dots in the #4 pot, 3 dots for #3 pot, and so on. There are no wear ridges. Should we measure bore diameter and attempt to re-ring? Also, assuming the engine can be re-ringed, when we pull caps and remove pistons, will we have to necessarily re-babbit too? or are the shells going to come out with the cap and rods? Thanks, Mark in NC |
10-31-2011, 05:47 AM | #2 |
Re: Banger Compression
Mark, if it still is a babbitted engine, you are gonna find there will be no "shells". The babbitt metal should be affixed to the rod and cap respectively.
If the lower end of the engine is clean & free of debris, I think I would re-install the head after making sure all valves are working and try to restart the engine As-Is. With the head off, you can get oil down around the rings and on the valve stems which should help get the sticky parts operating correctly again. After it has been running for a bit, many of your present issues may correct themselves. . . |
10-31-2011, 07:45 AM | #3 |
Sounds like good advice from Brent!
10-31-2011, 09:11 PM | #4 |
No ridge sound like no ware and sounds like you got a good one. Drive it. Iceman
11-01-2011, 01:01 AM | #5 |
I would have tried freeing the valves before pulling the head by using Sea-Foam in the gas and oil. But since you now have the head off you should be able to bring each piston to top dead center then push the piston to the side and look at the gap on the top ring. The gap should be about .012" with new rings. If you have a wide gap then now is the time to install new rings. Let us know what you find.
11-01-2011, 02:25 PM | #6 |
V4f |
11-01-2011, 06:40 PM | #7 |
Thanks, guys. We are going to flip her over on a stand, pull the pan to inspect, and reseal it if all is good. We will reinstall the head with a new gasket and attempt to run out of the car. Still have to get a distributor and carb, though.
11-12-2011, 12:00 PM | #8 |
Flipped her over about 45 minutes ago and pulled the pan. Seems like I need to clean her out good. Some sludge at the bottom and grit. Inspected crank and rods. Looks to be good. At some point a rebuild was done, because there are remnants of slag splash on the rods and caps from a re-babbit pour. The rods and caps have been marked with punch dots for each associated cylinder number. I pulled #1 and #3 piston and rod to inspect bores and piston rings. Rings are free and bores look ok, but not perfect. No significant scratches, but some very minor rust "bruising" but no pits. Would you guys recommend honing and reringing it? Also, the pistons say "Mcquay-Norris" on them and have a full-length split skirt. Any light to shed on that? I have not checked specs yet, but on the tops of the pistons it says "P15"
