Old 05-07-2010, 06:11 PM   #1
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Question Does anyone know of Turn signals that work with LCD Tail-lights, have been told the
Flasher will now work on many of them. I want to use my existing cowl lights as turn signals and parking lights, want the tail lights (LCD) and the Brakelighter to work also
Any recommendations to what i should use.
mark
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 05-07-2010, 06:20 PM   #2
Jim Parker Toronto
Jim Parker Toronto's Avatar
Default Re: Does anyone know of Turn signals that work with LCD Tail-lights, have been told t
Mark, that would be perfect. You could use any flasher when you hook that all up. LED's don't draw enough power themselves to operate (any) flasher. With incandesant lamps in the system, you could any flasher and it should work fine!
Jim Parker Toronto is offline   Reply With Quote
Old 05-07-2010, 06:27 PM   #3
msmaron
msmaron's Avatar
Unhappy Re: Does anyone know of Turn signals that work with LCD Tail-lights, have been told t
[QUOTE= LED's don't draw enough power themselves to operate (any) flasher. With incandesant lamps in the system, you could any flasher and it should work fine![/QUOTE]
OK but that tells me i have to go back to STANDARD Bulbs in the tail lights, Something that i wanted to avoid.. IS that what your saying?
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-07-2010, 06:43 PM   #4
Jim Parker Toronto
No, what are you using in the cowl lights?
Old 05-07-2010, 06:48 PM   #5
msmaron
msmaron's Avatar
Right now i have standard bulbs, i can change to double filament of needed, But concern is the TAIL LIGHTS that are NOW LCD??
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-07-2010, 06:54 PM   #6
Jim/GA
Jim/GA's Avatar
Conventional flasher units use the current draw going to the lights that are flashing to turn them off and on. A little spring inside the unit gets hot from the current flowing through it and opens up the contacts. With no current, the spring cools and the points close. Repeat...
LED lights draw very little current, so your lights may not flash with a conventional flasher because not enough current goes through it to open the points. However, there are "electronic" flasher units that are not sensitive to current load. If you can find one of them, you will be good. HTH.
You do not say if you are 6V, 12V, etc., so YMMV. But that's what you need.
Old 05-07-2010, 06:55 PM   #7
roccaas
roccaas's Avatar
I run a SigStat 900 with LED Tails, Standard bulb Cowls for directionals. I ran the Cowl light wires off of the harness into a pair of Cat Eyes Amber Driving lights.
Here's the wiring diagram.
http://www.film.queensu.ca/CJ3B/Tech/SignalWiring.html
roccaas is offline   Reply With Quote
Old 05-07-2010, 06:57 PM   #8
msmaron
msmaron's Avatar
Thank you for that, and i am 6 volt.....NOW where do i get that flasher!!
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-07-2010, 07:04 PM   #9
msmaron
msmaron's Avatar
Thank you for this, Where did you by the unit and if i am looking at correct this is it and seems very basic setup? IS this correct, LED tail lights work as signals and cowl lights with standard bulbs.
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-07-2010, 07:20 PM   #10
roccaas
roccaas's Avatar
Mine was on the car when I bought it, but I had to rewire everything last year. There is a weird little crimp at the brake light switch that I cannot grasp with logic, but it works.
Flasher is #A-13311 at Snyders.
Old 05-07-2010, 07:24 PM   #11
roccaas
roccaas's Avatar
Yes, it runs the LED's at the rear and bulbs in the cowls. Very basic wiring, I zip strap the wires and flasher down the steering column. The flasher does seem to be heat sensitive (it was under the hood originally), and the steering column seems more to its liking.
Old 05-07-2010, 07:31 PM   #12
Frank The Plumber
Mark, you just need to put any regular bulb on each side of your flasher, it can even be an indicator bulb on your instrument cluster, you just need something to trigger a draw response from your flasher unit.
Frank The Plumber is offline   Reply With Quote
Old 05-07-2010, 07:35 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Jim, I made a flasher that is completely independant of the load. I think Kevin from NJ has the information on his site. It consists of a capacitor and relay and will click even with no lights of any kind.
Old 05-07-2010, 08:43 PM   #14
msmaron
msmaron's Avatar
Tom can i see that?
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-07-2010, 09:33 PM   #15
dmaxweb
dmaxweb's Avatar
In the wiring diagram for the 902/903 switch, is the SigStat anything more than a simple DPDT on-off-on toggle switch? I don't want the lever mounted on the steering column but rater a small toggle under the dash rail.
dmaxweb is offline   Reply With Quote
Old 05-07-2010, 10:02 PM   #16
Dennis L Oberer
Email me for help...I have them....they work just fine.
Dennis L Oberer
Green Bay WI
Dennis L Oberer is offline   Reply With Quote
Old 05-08-2010, 12:00 AM   #17
Mike V. Florida
Mike V. Florida's Avatar
Electronic flasher unit should work not sure about the 6 volt, maybe for old VW's
Old 05-08-2010, 07:03 AM   #18
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
I have collected a whole set of turn signal wiring diagrams, and they may be found at
http://www.cedarcreekas.org/
in the "TechTopics" section. In addition there is an article there regarding installing them along with the changes required if you're converting to a 12v system.
To answer the original question: a standard flasher will work just fine with LED tail lights as long as there is an incandescent bulb somewhere else in the system: e.g., the cowl light (i.e., front turn signal bulb) or an indicator light or...
Regards,
Bill Lee
BillLee/Chandler, TX is offline   Reply With Quote
