11-24-2022, 03:59 PM | #1 |
Crankshaft Pulley Bolt (P/N 5-Z1900)
Hexagonal Box Wrench for Crankshaft Pulley Bolt (P/N 5-Z1900)
Will this tool work on a Model A crankshaft?Wrench.jpg Wrench.jpg |
11-24-2022, 04:16 PM | #2 |
Re: Crankshaft Pulley Bolt (P/N 5-Z1900)
1 3/8" ?
www.whidbeymodelaclub.com |
11-24-2022, 08:11 PM | #3 |
Yes 1 3/8
11-24-2022, 08:19 PM | #4 |
Yes, it's made for that specific purpose. Looks like you found an original tool, congratulations.
11-24-2022, 10:52 PM | #5 |
Your very lucky to find an original!
I've been looking for one for years with no luck. Everyone I talk with either knows exactly what I'm describing or have one that's not for sale. |
11-25-2022, 10:18 AM | #6 |
https://www.ebay.com/itm/18566513980...75.c101224.m-1
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 11-25-2022 at 10:23 AM. Reason: Addition |
11-25-2022, 10:44 AM | #7 |
Nice old original wrench but I think a 12 point would much more "usable" when turning over a engine. Space is tight.
Ruth "Sometimes you really DO need to read the whole thread" |
11-25-2022, 02:32 PM | #8 |
Bratton's has these:
11-25-2022, 03:02 PM | #9 |
Here is a thread on Ratchet Nut Wrenches if anyone is interested. https://www.fordbarn.com/forum/showt...het+nut&page=2
11-25-2022, 03:53 PM | #10 |
Thank you very much!
11-27-2022, 11:05 AM | #11 |
I caution you to paint / tape the handle of your wrench a bright Dayglo color to remind you to remove it from the engine before starting the engine. Unfortunately, more than one Model A'er has forgotten to remove the wrench with some interesting results.
Another tip is for those who have a tool box between the frame horns. The box blocks the hand-crank hole, so the 1-3/8 offset wrench is a must have for turning the engine to time the ignition.
Bob Bidonde Last edited by Bob Bidonde; 11-28-2022 at 08:45 AM. |
11-27-2022, 05:21 PM | #12 |
Be sure to read & heed what Bob B. said in post #9.
Fortunately, the only thing that happened to me was I found the fastest way to loosen the crank pulley bolt with the engine still in the car! |
11-28-2022, 05:24 PM | #13 |
I bought a 1/2 inch drive 1 3/8 inch socket. Used an extension and rachet to get to it from the crank hole in the grill. Much easier than a wrench. Because it sticks out between the grill and bumper it is hard to forget to remove it. Although I probably could.
