09-16-2022, 08:59 PM | #1 |
1948 ford truck
I have a new project that I want to return to original condition. The truck originally had column shifter. The pic shows what current transmission looks like. I’m hoping to find a picture or dimensions so I can rebuild this transmission frame or locate another one. Thanks for looking
09-16-2022, 09:30 PM | #2 |
Re: 1948 ford truck
Nice project, keep the pictures coming during your progress.
09-16-2022, 11:11 PM | #3 |
Re: 1948 ford truck
Congratulations Ken on your new project. These are great old Trucks. I wish you well. |
09-16-2022, 11:14 PM | #4 |
Re: 1948 ford truck
1948 Ford F-1 Light Duty Truck - from the Original Sales Brochure |
09-16-2022, 11:18 PM | #5 |
Re: 1948 ford truck
1948 Ford F-2 Light Duty Truck - from the Original Sales Brochure |
09-17-2022, 12:29 AM | #6 |
Re: 1948 ford truck
09-17-2022, 08:17 AM | #7 |
Re: 1948 ford truck
https://www.ford-trucks.com/forums/7...ss-member.html
Post #6. I have the transmission mount for an F1. In a month or so, when I have a chance, I may have an F1 crossmember. Your current 'member looks like a hacked up one from an F2/3, though it is missing the recess for the rubber mount. Be curious to know if that was welded in or bolted/riveted. Originally transmission crossmembers were riveted. If it has rivets, cut a slot in rivet head with a cutoff wheel, knock head off, then with a pointy persuader in an air hammer, send it across your shop.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 09-17-2022 at 08:32 AM. |
09-17-2022, 08:55 AM | #8 |
Re: 1948 ford truck
Thanks for your interest and comments. To answer a couple of questions, orcas is a beautiful place but there is a mountain range between there and Ellensburg.
The cross member is riveted on and someone modified it with 1/4 flat bar. I’ll share pics as progress goes on. Thanks again. |
09-17-2022, 08:57 AM | #9 |
Re: 1948 ford truck
I see.that now. Most likely an F1 that was hacked to fit the 4 speed Spur gear with the F2/3 rear mount.
I dig coal, which provides motivation for EVs. |
09-17-2022, 09:54 AM | #10 |
Re: 1948 ford truck
The column shift wasn't introduced to the F1 models until midway through the 1950 model year. Typically, the light duty 3 speed floor shift transmission was found in most '48s although the 4 speed non-syncro and the 3 speed heavy duty were available.
Your transmission cross member and yoke are owner mods. This is my only ready pic of the mount. The yoke cradle straddles the cross member on the F1s.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
09-17-2022, 10:27 AM | #11 |
Re: 1948 ford truck
Was the drive shaft different between the 3 speed top loader and the 4 speed? Have a 3 speed open drive shaft transmission in my garage that I got a few weeks ago and the drive shaft as well. The connection is different between the 2 as I look at it. I don't have the slip yoke for mine but had one last year to compare this set-up to.
09-17-2022, 10:41 AM | #12 |
Re: 1948 ford truck
Well, that's quite the hacked out crossmember. Big ol' tranny too! Clark 5 speed?Doesn't look like a regular Borg Warner T-9 crash box, and those should bolt right into a half ton with no mods, just a different bolt on mount. I have a column shift 3 speed here that you can have. It looks pretty rough on the outside, but who knows? My wife's sister lives in Ellensburg and she's heading over the pass in a couple of weeks to visit her. I could toss the tranny in the back of her subaru. She is easy with that type of stuff. Does the truck run? V8 or six? I can get a pic or two of the trans and post it up. Mac VanPelt here on the forum is a wealth of knowledge and parts for a rebuild. Truck looks to be in excellent condition and I'm gonna speculate it's from the Right side of Oregon.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
09-17-2022, 11:30 AM | #13 |
Re: 1948 ford truck
That is a T9. The rear mount is from a 48-50/early 51 F2/3 with no park brake drum, no provision for brake band(park brake was in rear drums). I have one that is going on my T9 in the Marmon Herrington, since the brake drum is on the transfer case, and the original is cracked.
I would like to see the cooter-bobbery involved in putting a Clark behind an 8RT hogshead...
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 09-17-2022 at 12:52 PM. |
09-18-2022, 04:54 AM | #14 |
Re: 1948 ford truck
Saw this Fully Imported 1948-1950 Ford F-1 at a local Car Show today. |
09-18-2022, 07:19 AM | #15 | |
Re: 1948 ford truck
Page from the 1953 Ford truck full-line brochure showing the option: http://oldcarbrochures.org/United%20...Line-50-51.jpg Ok, back to our regularly scheduled discussion... |
09-18-2022, 08:50 AM | #16 | |
Re: 1948 ford truck
All ot, as this is a T9.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 09-18-2022 at 09:10 AM. |
09-18-2022, 10:55 AM | #17 |
Re: 1948 ford truck
Gary, thank you for the offer of the 3 speed transmission, but I have one ready to go. You are right about where the truck came from. Joseph ore. And the gal we bought it from was as nice as they come. Such a beautiful place. It was a five hour drive from Ellensburg, but worth the trip. Thanks again and I will post pictures of progress.
09-19-2022, 12:38 AM | #18 |
Re: 1948 ford truck
Australian 1949 Ford Freighter. While on the subject of these models of Ford Pickups, I thought that you would like to see this difference. Notice the positioning of the Parking Lights on the Australian 1948-1950 Ford Trucks. |
09-19-2022, 12:39 AM | #19 |
Re: 1948 ford truck
Canadian 1948 Ford F-47 Pickup. Notice that the Canadian 1948-1950 Ford Trucks had the Parking Lights mounted and the ends of the top Grille Bar, just like the USA models. |
09-19-2022, 08:22 AM | #20 |
Re: 1948 ford truck
I wonder, was the park lamp relocation done for law purposes?
