08-31-2019, 02:08 AM | #41 | |
Re: ford B engine
Charlie Stephens |
08-31-2019, 02:11 AM | #42 | |
Re: ford B engine
Charlie Stephens |
08-31-2019, 03:35 AM | #43 |
Re: ford B engine
Regarding the oil passage along the side of the block. No, it does not pass oil to the valve chamber, it sends the oil to the mains and cam bearings. I'm not sure if one gets the oil before the other, I don't have a 4 cyl here.
08-31-2019, 10:20 AM | #44 |
Re: ford B engine
thanks, I did actually read that someplace after I posted this
08-31-2019, 10:22 AM | #45 | |
Re: ford B engine
08-31-2019, 11:44 AM | #46 |
Re: ford B engine
08-31-2019, 12:35 PM | #47 | |
Re: ford B engine
08-31-2019, 12:37 PM | #48 |
Re: ford B engine
ok, next question,if anyone knows. to me it looks like the spaceing of the B and A flywheel housing are the same. is there any reason you cant leave the B oilpan / flywheel housing alone and still bolt on an A bellhouseing and trans?
08-31-2019, 01:28 PM | #49 | |
Re: ford B engine
No provision for rear motor mounts. Bob |
08-31-2019, 04:50 PM | #50 |
Re: ford B engine
well id have to disagree, mine has mounts just like the A on the top cast part. you can see them in the pictures unless they are in a different position than the A?
08-31-2019, 04:52 PM | #51 |
Re: ford B engine
08-31-2019, 04:54 PM | #52 |
Re: ford B engine
got pan and flywheel off anyways. things look good washed it out with degreaser and cleaned it up some pan and flywheel need to go to the hottank really.
isn't that balanced crank prity prity |
08-31-2019, 07:28 PM | #53 | |
Re: ford B engine
Charlie Stephens |
08-31-2019, 07:34 PM | #54 |
Re: ford B engine
Heck, I'd try to use the B transmission. At least it has a synchronizer for 2nd & high gear. The drive shaft might need to be shortened though but it's do-able. The pedals is where the problem lies but it can also be worked around if a person wanted to go that route.
08-31-2019, 07:52 PM | #55 | |
Re: ford B engine
08-31-2019, 08:38 PM | #56 | |
Re: ford B engine
08-31-2019, 08:41 PM | #57 |
Re: ford B engine
no, but late style v8 gears will go in a b case. clings make a set up to mount pedals and wish bone, i made my own once, still have the jig for locating the pedal shaft
08-31-2019, 09:02 PM | #58 |
Re: ford B engine
interesting. I have 2 B transmitions, but have no idea what they look like inside, where I have a ton of A stuff. think it will still get an A trans behind it
09-01-2019, 03:14 PM | #59 |
Re: ford B engine
Great post; The Aftermarket Model A pedal bracket is a nice piece and makes the later transmissions a joy to drive. Newc
09-02-2019, 10:56 AM | #60 |
Re: ford B engine
