11-12-2012, 12:38 PM | #1 |
leak in radiator
I have a really small leak in drivers side bottom of radiator . One or 2 drops when i go out. It seems to be coming from the fold in the bottom . Do i have to take whole radiator out or can i put in some kind of sealer. i saw one in snyder's catalog called ceramic motor seal. Thank you.
11-12-2012, 12:43 PM | #2 |
Re: leak in radiator
one jar of Bar's Leak !
Wayne |
11-12-2012, 12:43 PM | #3 |
If you can confirm it is not coming out of the overflow tube on the drivers side, a sealer might not be a bad idea. My opinion is that sealers are generally a band-aid that you can use while you save up $ to get it to a radiator shop.. if it is leaking in one place, other places might be thin or fatigued enough to need attention in the near future.
Some have used sealers and likely never had an issue again, but I do wonder if a sealer would reduce flow and or effective cooling in the tubes (?).. Maybe someone with more experiences in sealers will chime in.. Maybe not a direct answer to your question, but hope it helped - Dave in Boise |
11-12-2012, 01:14 PM | #4 |
you can stop leaks in the radiator with stop leaks, but as dave said, its a band-aid fix, it will work for a while but will be harder to fix when you do pull radiator to send in to have it fixed, the shop has to clean out the sealer before they can fix the leak, more money spent, if your just trying to get the car so you can enjoy it for a while do it, but sooner or later, usually sooner its going to have to go to the shop
11-12-2012, 03:01 PM | #5 |
I would add a short piece of rubber hose to the overflow and have it exit away from the crossmember. This way you can make sure the drop isn't condensation coming from the overflow pipe. Also make sure it isn't a little leak from the bottom hose. If you can determine the leak is from the bottom tank you might get lucky and find it's easily soldered in place. If the solder job is easier with the radiator out, then remove it. It doesn't take long to remove and makes the job much easier. If the small leak is in the center of the core, where it isn't easy to reach, then I'd try some kind of radiator sealer first. |
11-12-2012, 04:58 PM | #6 |
11-12-2012, 08:34 PM | #7 |
Try Alumaseal. It won't clog your radiator
11-12-2012, 10:31 PM | #8 |
Will Alumaseal work on our brass radiators?
11-12-2012, 10:48 PM | #9 |
For a simple fix if it is in an area with easy access and doesn't show consider this. Clean the area real well and cut a piece of cotton cloth (t-shirt material) slightly bigger that the area that is leaking. Rub silicone sealent into the cloth really good and apply it over the area. Smear a touch more over the patch and let it cure. If you use black cloth and silicone it will be pretty tough to see. If you need to remove it a bit of scraping and wire brush work and it is gone. I've done this quite a few times on different things and it works suprisingly well.
Dave |
11-12-2012, 11:44 PM | #10 |
I like your idea ,it should work being there is no pressure in the radiator. But will the silicone sealent melt when the radiator heats up?
11-13-2012, 12:37 AM | #11 |
Don't look for the EASIEST or CHEAPEST fix, look for the BEST fix.
11-13-2012, 04:53 AM | #12 |
One of my first posts on the Fordbarn was about my radiator and if I should use stop leak to fix it. Someone responded “just fix it right”, that’s been my philosophy with all problems since. The end result is, my A is very dependable and my knowledge about the car has increased. Pulling the radiator is not difficult; Les Andrews book outlines it quite well. As a friend would say, “If you do not have time to fix it right, when will you have time to fix it a second time”
Paul
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
11-13-2012, 05:05 AM | #13 |
Yes, but if a cheap and quick fix works why spent time, money and angst striving for perfection. Life's just too darn short.
11-13-2012, 06:27 AM | #14 |
11-13-2012, 06:45 AM | #15 |
John,
I can see your point. I personally enjoy working on it. For me it’s half the fun. It is an easy fix to take apart and put back together. My cost was $75.00. Paul
11-13-2012, 07:01 AM | #16 | |
Just an idea as a temporary fix. But would probably be good for a long time. Dave |
11-13-2012, 09:19 AM | #17 |
LOL on critical parts there is no such thing as a quick, tempory,cheap fix, ask any garage owner, that type of fix is there bread and butter, a radiator repair now will save you a big tow bill and probably an engine over haul, some body on here said"spend a little money now, or a bunch alter", something caused the radiator to start leaking, probably viberation from the engine, it will only get worse, a crack or split in the seam of the radiator will only keep getting bigger
