07-24-2010, 12:46 PM | #1 |
Ford Script head...any info appreciated
Recently came across a great head with the ford script on it, When was it used, the years...looking for any information on this for Fine Point Judging.
Under the script is the letter "N" stamped into it also.
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
07-24-2010, 03:13 PM | #2 | |
Re: Ford Script head...any info appreciated
YES it does have the casting date very clear... Okay your information as always helps a great deal! Thank you
07-24-2010, 06:11 PM | #3 |
I see a embossed "W1" near the distributor hole on a lot of Model A cylinder heads, including mine.
What does it signify?
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
07-24-2010, 07:38 PM | #4 |
Mark , this question was asked before on the old Fordbarn. Its a Early FORD replacement head. I have a n.o.s. one i tried to sell at Hershey last year.$125.00 ... I am putting it on the 170b. just because. If you put in on for a Fine point judging what will it be marked down as??? Its not a reproduction> It is a FORD orginial part. no one else made it. Just thinking???
07-24-2010, 08:12 PM | #5 |
Concur with Pete, it is an original Ford part but it is a replacement after production. I have one I bought from B.S. Wisnouwski years ago So many guys get screwed today buying something labeled FoMoCo. These are service replacement parts. Some smart engineer figured a way to make one part fit from 1928 to 1934 for example. I've bought stuff like this thinking it was NOS and found out later. Still good stuff for a driver as opposed to repro junk.
"A wet bird doesn't fly at night." |
07-25-2010, 03:56 AM | #6 |
We get the W1 heads here too. I always presumed that it stood for Windsor. Incidently my early Canadian Block has a large W cast on the inner surface behind the timing gear |
07-25-2010, 04:40 AM | #7 |
Thanks for the response Bick.
Maybe the "W" does represent Windsor, or perhaps Walkerville, which was amalgamated with Windsor in 1935. Ford opened a plant in Walkerville in 1904. |
