08-26-2014, 11:46 AM | #1 |
adjustin valves
A easy way to adjust valves when you are rebuilding a model A engine. Is make a handle with extension on it, you can weld it to a old cam nut. It should stick out farther than the crank shaft. Then before you put the timing gears on ,use that to turn the cam to adjust the valves. With adjustable lifters it is easy and fast. You will not have to turn that stiff new rebuild.
08-26-2014, 11:58 AM | #2 |
Re: adjustin valves
That sounds like a good idea. Thanks for the tip.
08-26-2014, 11:59 AM | #3 |
Re: adjustin valves
good idea george. i adjust them with no valve springs installed, just hold them closed with my thumb. i give them a final check after installing springs.
08-26-2014, 12:38 PM | #4 |
Re: adjustin valves
