Old 04-07-2018, 01:19 AM   #81
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Chasing the knock.
When the pin drops into the cam gear dimple, the rotor should be exactly as in this picture.
I'd loose the rubber fuel line, and run steel all the way.
The points should be adjusted to .020".
Old 04-07-2018, 10:51 AM   #82
Bob C
This gas line and filter should work on your indented firewall car with the
non side bowl carburetor. http://www.mikes-afordable.com/product/A9155L.html
Bob
Old 04-07-2018, 05:07 PM   #83
Garagekulture13
Garagekulture13's Avatar
About the fuel line that is a carb I borrowed. My carb has the side sediment bowl and it will be going back on. It fits the current fuel line.
Sorry but being in a rush before work while doing my final timing checks I left the rotor button out. That's why she wouldn't fire. But she is back together and running. You be the judge of whether the new gears fixed the knock.
Before
https://youtu.be/3R3eLKlvVmU
After
https://youtu.be/C-MMJRXug8E
Sent from my SM-N950U using Tapatalk
Garagekulture13 is offline   Reply With Quote
Old 04-07-2018, 06:32 PM   #84
1931 flamingo
1931 flamingo's Avatar
Sounds a lot better than it did ! !
Paul in CT
Old 04-07-2018, 06:41 PM   #85
michael a
michael a's Avatar
What's the sound like in SLO idle
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 04-07-2018, 06:58 PM   #86
Garagekulture13
Lower idle
https://youtu.be/DeSld6LHVcg
Old 04-07-2018, 08:37 PM   #87
michael a
michael a's Avatar
Originally Posted by Garagekulture13 View Post
Lower idle
I really can't tell on that video do you think the knock is gone
Old 04-07-2018, 09:02 PM   #88
1955cj5
1955cj5's Avatar
Before
After
I think it sounds good!
You sure got rid of all that clattering...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-10-2018, 12:54 PM   #89
100IH
How difficult was it to remove the crankshaft timing gear? Can be tough. Good sounds after all of the work, a good introduction to the more common Model A's miseries and cures. You might try an even slower idle with less advance and idle speed screw. When setting timing do it at the third notch in the up position. That way, when you're so inclined, you can go levers up and see how slow and quiet an A can really be.
100IH is offline   Reply With Quote
Old 04-11-2018, 07:44 PM   #90
Garagekulture13
The knock is gone. I still can hear some what I believe to be some valve clatter. Nothing drastic. The car has set up for some time so I hope with some drive time things will get settled in. I put in VR1 20-50 oil in and Marvel Mystery oil in the gas. Also with some of the inspection panels off when I was driving it I could hear some noise from the trans. When I got back I found it was low so I added some 600W to it and so far that has fixed that. I believe to be lucky and the crank gear came off pretty easy. I noticed the gear puller with the finer threads pulled it off when the puller with the more course threads wouldn't do much.
Old 04-11-2018, 08:17 PM   #91
1955cj5
1955cj5's Avatar
I'm told those aluminum cam gears can make a little noise.
If the transmission was low better check the rear end if you haven't already.
Nice work and informative posts!
Old 04-12-2018, 07:58 AM   #92
Railcarmover
Aluminum gear can rattle,even if they backlash correctly. Now that you have it running right did you check the rod and main bearing clearances? it would suck to see all this work ultimately hammer out a loose bearing..
Railcarmover is offline   Reply With Quote
Old 04-12-2018, 03:14 PM   #93
Garagekulture13
I did not check clearances. However today I noticed while running around 40 mph I could bring the timing lever up about a quarter of the way and the motor would quite down. What's the reason fo this?
Old 04-12-2018, 03:24 PM   #94
Bulligen
Bulligen's Avatar
Sounds Great, Congrats on a job well done!
Bulligen is offline   Reply With Quote
Old 04-12-2018, 03:48 PM   #95
40 Deluxe
Probably worn bearings/pistons. Retarding the timing lowers combustion pressure thus making rattles quiet down. This was an old used car dealer trick to sell a clunker. The engine would sound good until the new owner had it tuned up. Setting the timing to proper specs would bring on the knocking.
Old 04-12-2018, 04:32 PM   #96
Art Newland
Art Newland's Avatar
You for sure want to check clearances, many things can click and clack without causing much trouble, if the bearings are loose they will get worse a lot faster.
"whatever works!"
Art Newland is offline   Reply With Quote
Old 04-14-2018, 04:27 PM   #97
Garagekulture13
This happened last night on the way home. When I started the car at work I noticed right away it sounded different. I work 2nd shift and got off at 11pm. So I decided it was a nice night I'd run by the lake on the way home. When I left the lake I noticed I had it to the floor and she didn't want to pull anymore. I was running about 45mph. The headlights were pulsing and when I got home I saw the driverside light was very dim. I don't know how or if it's all related. I'm just telling what happened. Once home she was running very poorly but she DID get me home. I pulled the plugs and found #4 was fouled and #3 was looking bad also. No gas smell on the plugs and the car never has smoked. I did mess with the metal shielded wire that runs up from the dash panel up to the light under the dash rail while sitting in the parking lot at work. It looked like it was pinched.
Old 04-14-2018, 04:36 PM   #98
cr1248
I may have missed it on an earlier thread but did you check the oil pump? A 29 that I worked on had a terrible knock and all it needed was the oil pump cleaned.
cr1248 is offline   Reply With Quote
Old 04-14-2018, 04:40 PM   #99
Bob C
What was the ammeter showing when this was happening?
Bob
Old 04-14-2018, 04:52 PM   #100
Garagekulture13
Bob
It was more or less pegged to the right.
