01-08-2018, 07:04 PM | #1 |
won't start problems
Working on a 28 Pickup. Excellent engine. Died while driving. Checking all the basics. No spark at points. No power at coil with switch off. Good battery. Might be condenser. How do I remove condenser with distributor on engine or is it possible? What else should I check? Ignition switch?
01-08-2018, 07:30 PM | #2 |
Re: won't start problems
Try your horn. Probably the fuse.
01-08-2018, 08:58 PM | #3 |
Do you have a fuse at the starter ?
Do the lights work ? Could be as simple as a poor battery connection. Time to get a wiring diagram and test light then get your hands dirty. It shouldn't be difficult to fix. |
01-09-2018, 02:23 AM | #4 |
Here's a couple
01-09-2018, 02:49 AM | #5 |
Read #17 for how to change the condenser the quick and easy way.
https://www.fordbarn.com/forum/showt...+tom+wesenberg |
01-09-2018, 03:51 PM | #6 |
01-10-2018, 07:09 AM | #7 |
See Tom's post #5 above.
Make sure those "not connected" wires are not grounding out somewhere. Without lights to indicate "switch on" there could be a short in that circuit. Keep digging, you'll get it. Enjoy the adventure. |
01-10-2018, 07:41 AM | #8 |
I think it depends on which manifold is being used would depend on whether the condenser can be changed. But, it only takes a couple minutes to remove the distributor. The ignition timing doesn't have to re set in these monsters when reinstalling the distributor.
01-10-2018, 09:05 AM | #9 |
If engine has the armoured cable going from distributor which is bolted to one of the head bolts ... drain radiator BEFORE loosening the head nut so that coolant does not end up in oil pan.
01-10-2018, 04:52 PM | #10 |
So after a couple of hours and replacing 2 condensers it still won't start. I have power all the way to the points at about 6 volts. The exhuast manifold has the heat exchanger on the top so I had to pull distributor to change condensers. Not too bad. Charged the battery and cranks well. rest point gap and retimed according to book. No visible spark with cranking. Any ideas?
01-10-2018, 05:07 PM | #11 | |
01-10-2018, 05:27 PM | #12 |
Is there power at the coil??? If so the problem is in between there and the points.
01-10-2018, 07:11 PM | #13 |
You should have 6 volts all the time on one side of the coil, and with the key ON and engine cranking, the other side should go back and forth from voltage to ground, as the points open and close. Connect your analog volt meter and watch for the needle to bounce as the points open and close, or watch your test light flicker on and off.
01-10-2018, 08:30 PM | #14 |
Do you have spark in the distributor?
01-10-2018, 08:57 PM | #15 |
Make sure the rotor is turning when cranking. Timing gear could have gone south.
01-10-2018, 09:14 PM | #16 |
I have power at the coil and points now. Power at both sides of coil with switch off and drivers side with switch on. The rotor does turn. There is spark at the points when I set the timing with a light per Les Andrews but no spark when cranking. I pulled the points plate off to look and found a newer style wireless lower plate that has power to it. Tried a different rotor. Was able to get a spark through high voltage lead to ground with manually opening points.
01-10-2018, 09:31 PM | #17 |
Are the points opening?
New points can close up as the wear pad wears down. |
01-11-2018, 02:29 AM | #18 |
Start it with the hand crank. I had the same problem a few years ago, but after hand starting the engine and letting it run a few minutes, all was fine again.
BTW, those wireless lower plates are garbage, and that's where it would be if it came on my car. |
01-11-2018, 07:03 AM | #19 |
shut my pickup down after a short drive,would not start again no how. coasted it down a small incline,popped the clutch and it started immediately.has never happened again,knock on wood,this was 2years ago.
01-11-2018, 07:43 AM | #20 |
2x Tom's "ditch it!" suggestion. Go with a new lower plate that has the longer flexible wire.
Marshall |
