10-26-2013, 06:32 PM | #1 |
Radiator question
Hello all, I'm used to a closed radiator system, and my new project (31 Vicky with a stock engine and cooling system) brings my question.
I know they are not a closed system and there will be some coolant loss, but what is normal? After driving for a couple days it is down about 1 gallon. There is no leaks seen anywhere in the entire cooling system ( except the overflow after filling up) no leaks at the head exhaust looks fine, no fluid on the ground and the oil is normal. Thanks in advance for all help, it's always appreciated. Nick |
10-26-2013, 07:01 PM | #2 |
Re: Radiator question
It sounds like your filling the rad to far up. Most A's are happy at a level just at the baffle in the upper tank which is just above the core or tube openings. Its normal for it to find its own level by coming out of the overflow if filled higher than this.
10-26-2013, 09:15 PM | #3 |
