Old 01-29-2018, 12:47 PM   #21
SeaSlugs
SeaSlugs's Avatar
Default Re: Runs for about 10 minutes and the just quits
Originally Posted by Ernie Vitucci View Post
Tank junk suggestion...If the tank is dirty, one can drain it and let it dry out overnight and then take the hose of your shop vacuum and then vacuum out the tank the following morning. You will most likely hear and feel 'Junk' coming up the hose. I'll grant that you can't get everything out of the tank, but if you do this a couple of times, you will get a great deal of the junk out of the tank. I have also put a second glass sediment bowl in the fuel line, like one from a 55 Thunderbird or such...put it level in the fuel line and put a good sized magnet in the bowl...the car will run much better and the magnet will catch lots of fine stuff that would clog up the carburetor. Ernie
PLEASE do not do this.... unless your life insurance and homeowners insurance and car insurance is paid off and you got an extra life in your pocket...
shop vac + explosive fumes = huge bang.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-29-2018, 02:31 PM   #22
100IH
No,No,No. Do not vacuum the tank. The fumes will ignite in the vacuum and explode and burn. Also don't assume without verifying that the fuel is starving. see#13.
100IH is offline   Reply With Quote
Old 01-29-2018, 03:22 PM   #23
Gary WA
Gary WA's Avatar
Very dangerous to do even after draining tank, Metal will still hold fumes and can explode
, not many people will weld on a drained cleaned out tank!!!!!!!!!!!!!
www.whidbeymodelaclub.com
Old 01-29-2018, 03:32 PM   #24
Tom Endy
Tom Endy's Avatar
The same goes for using a vacuum to clean up the old gasket material when replacing the gas gauge components. Resist the temptation to use the vacuum or you may likely suck gas fumes into the vacuum where the sparking brushes in the vacuum motor will light things off.
Tom Endy
Old 01-29-2018, 03:37 PM   #25
Curtis in MA
A guy I knew hocked up a hose to the exhaust of his modern car, ran it into the tank and the welded it. No oxygen so no explosion.
I would not try it but he did.
Curtis in MA is offline   Reply With Quote
Old 01-29-2018, 03:55 PM   #26
Jw
condenser
Jw is offline   Reply With Quote
Old 01-29-2018, 05:59 PM   #27
Jw
condensor
Old 01-29-2018, 07:21 PM   #28
Jack S.
I had an unusual one about 12 years ago. Same issue as you described. Turned out the add on pipe on top of the shutoff inside the tank had come loose and fall off. It was rolling around in the tank as you drove. It would eventually end up just over the hole that the gasoline flows into at the center bottom of the tank. The piece of pipe would then, in turn, block the flow of fuel down the line to the shutoff and carb. If you sat and waited for about 5 minutes, the flow of gas got around the blockage and the car would run for another 5 to 10 minutes and then would repeat the situation once again. A long pair of tweezers grabbed the culprit out and never had a problem since.
Jack S. is offline   Reply With Quote
Old 01-29-2018, 07:23 PM   #29
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by Jw View Post
condensor
That's 2 condenser in 2 hours. You need to buy better quality condensers.
Old 01-31-2018, 02:38 AM   #30
pooch
pooch's Avatar
Does it run and stop in 10 mins NOT being driven?
Easy elimination check whether fuel or spark.
pooch is offline   Reply With Quote
Old 01-31-2018, 04:44 AM   #31
3.6rs
3.6rs's Avatar
Already found the solution to your problem, "tagroff" ?
3.6rs is offline   Reply With Quote
Old 01-31-2018, 09:02 AM   #32
Robert/Texas
Robert/Texas's Avatar
I got interested in this thread because I also have a '28 RPU and the exact same thing happened to me some time ago. It turned out that the gas cap vent was clogged as others have mentioned.
The other thing that interested me were the gas tank postings. Back in 1960 when I was stationed in the army in southwest Germany I had a 10 year old Mercedes 170S. Two of my friends and I had leave and decided to drive to Paris in it. We didn't get far when it started missing badly. We pulled in to a Mercedes dealer in Saarbrücken and they found that there were a lot of leaves in the gas tank. They fished a lot of them out so I paid them and we continued on. We only got about 50 km or so when the problem continued. We stopped in an auto repair shop in a little French town and my buddy, who spoke some French, explained the problem to the mechanic. He put the car on his lift and then drained the gas. Next he took a cutting tool and cut a hole in the tank. Lots of leaves came out which lead me to believe that I had been vandalized. After that he welded a patch on it with an acetylene torch. All three of us backed up when he did this but nothing bad happened. I paid him and we went on to Paris and had a good time there (another story).
Robert
Robert/Texas is offline   Reply With Quote
Old 01-31-2018, 02:53 PM   #33
1928Mik
1928Mik's Avatar
In my case, it's the needle valve, sticks occasionally. I carry a small hammer and just tap the side of the carb and it always starts after that. I'll take it out at some point this winter and use carb cleaner and a Q-tip....
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 02-01-2018, 08:42 AM   #34
Patrick L.
Patrick L.'s Avatar
Its been a few days and will be interesting to hear what he found.
It should be fairly easy. When it quits, check for secondary spark ASAP. If there is spark, check for a good solid fuel flow.
Old 02-01-2018, 08:58 AM   #35
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
You should try to deal with a tank that LITTLE KIDS added Berries from a Chinaberry Tree +&%^%$$%#@--- Or a roaming GUM WRAPPER, or a Handi-Wipe, disintegrating in the tank. Or when Little Kids topped off the tank, with the GREEN Garden Hose!!!!
Bill Beenthere
"THE ASSISTANT GURU OF STUFF"
Old 02-01-2018, 12:21 PM   #36
Gary WA
Gary WA's Avatar
Originally Posted by tagroff View Post
I have a 1928 it starts fine runs like a top for about minutes then quits and won't retire.
Any updates????
Old 02-02-2018, 09:19 AM   #37
mike657894
mike657894's Avatar
Check the plugs after it shuts down .
mike657894 is offline   Reply With Quote
Old 02-02-2018, 12:09 PM   #38
100IH
Well, looks like he mighta/did use the vacuum.
Old 02-02-2018, 01:07 PM   #39
Jw
so what was the root cause of failure?
Old 02-02-2018, 08:38 PM   #40
Big hammer
Oh I hope not! I think it was something simple! And he got it going, he’s probably been on a nice long drive.
get a bigger hammer tap done
