05-22-2017, 08:20 PM | #1 |
40 roof antenna question
I am thinking of installing a radio and roof antenna on my sedan. before I cut a hole in the roof I would like to know what the inside finish looks like. There will be a hole in the headliner I guess. Is there a grommet? I think there will be a hole in the inside shelf also. The center area on the inside was rusted away and I had to repair that. Can anyone post a couple photos and some explanation of what the inside looks like. Thanks
05-22-2017, 09:10 PM | #2 |
Re: 40 roof antenna question
The antenna will come with a template to show you where to drill. It fits on the top of the roof front center. No hole in the headliner, the antenna comes through behind the rear view mirror. Remove the mirror and you should see a hole.
05-23-2017, 09:25 AM | #3 |
You will have drill a hole in the dash for the antenna to attach to the radio. The hole is also the main way to support the radio also. If it was me I would leave the car alone and not drill any extra holes. If you need music get a "boom box" and put it on the back seat.
05-23-2017, 10:01 AM | #4 | |
05-23-2017, 10:19 AM | #5 |
As Ken said. Plastic button looks like this.
It just sits in the hole. Last edited by 19Fordy; 05-23-2017 at 10:31 AM. |
05-23-2017, 10:31 AM | #6 | |
05-26-2017, 08:19 PM | #7 |
I repaired that area. It was rusted away. I used the garnish to know where the mirror holes should be. What size is the hole and where is it on the inside. Thanks to all.
05-27-2017, 01:40 PM | #8 |
if your going to use a car cover the antenna is a prolbem. i mount the ant on a bracket on the rear bumper bracket no holes to drill
05-28-2017, 08:27 AM | #9 |
The comment on the car cover is a good one that I hadn't thought of.
05-28-2017, 08:47 AM | #10 |
Is there any other type of antennae you could use without
having to make a hole in your roof? Roof hole = potential leak. Please don't be tempted to mount antennae on you cowl. |
05-28-2017, 09:18 AM | #11 |
I mounted my antenna on my rear bumper,because I didn't want to drill a hole.Also I wasn't sure if the original antennas was FM capable.
Milt/Las Vegas |
05-28-2017, 02:27 PM | #12 | |
Me? I don't care for the look of an antenna on the back bumper or for that matter, anywhere else other than stock.
05-29-2017, 11:03 AM | #13 | |
Milt/Las Vegas |
