01-18-2020, 04:50 PM | #1 |
Engine pans
Guten Abend!
Does anyone have mounted these parts and can show me a picture how it looks when they are installed? Is this a new idea or an addition from the car era back the 30-th? https://www.brattons.com/eng-splash-...er-coated.html Thanks!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
01-18-2020, 04:58 PM | #2 |
Re: Engine pans
Ford installed them originally. Many people have removed them over the years. They use two of the oil pan bolts and two bolts to the frame.
01-18-2020, 06:18 PM | #3 |
Re: Engine pans
Some say that engine splash pans aid in cooling the engine. I really can't say from experience if that is true or not.
01-18-2020, 06:57 PM | #4 |
Re: Engine pans
Also as a ground path, a ground from frame to engine.
01-18-2020, 07:41 PM | #5 |
Re: Engine pans
01-18-2020, 08:37 PM | #6 |
Re: Engine pans
I feel they are important. They direct air across the exhaust manifold and the block itself, instead of letting it escape out the bottom. They also look good and keep the engine compartment cleaner. And as stated about they also assure an electrical path, Engine to frame.When you put them in place from the bottom, it is very obvious what bolts are used to hold them on.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
01-18-2020, 10:42 PM | #7 |
Re: Engine pans
Kind of hard to take pictures of but I gave it my best attempt
01-18-2020, 11:18 PM | #8 |
Re: Engine pans
Very helpful when you don't use an air filter on the carburetor.>
01-18-2020, 11:40 PM | #9 |
Re: Engine pans
I agree with Whirnot in post #6. I think they help with cooling the engine, but certainly will catch your air-maze filter if it falls off ! Also, they are original equipment, so I have them installed on my car.
01-18-2020, 11:48 PM | #10 |
Re: Engine pans
Werner, take a look also at these older threads on the engine pans. The two most common problems are (1) difficulty with the installation due to the mount points not quite being where they're supposed to be or the holes being too small and (2) vibration at the mount points causing noise as well as wear on the flanges. Various fixes are proposed in the threads for both issues.
https://www.fordbarn.com/forum/showt...7430&showall=1 https://www.fordbarn.com/forum/showthread.php?t=4312 https://www.fordbarn.com/forum/showthread.php?t=45594 |
01-19-2020, 02:15 AM | #11 |
Re: Engine pans
I have had engine pans on my sedan almost 40 years and never had a problem with them breaking. I was lucky and found original ford plans and had them powder coated black.
01-19-2020, 07:31 AM | #12 |
Re: Engine pans
Hallo and a big "Thankyou" at all for the unanimous positive informations.
I will order now the sheets from Brattons. They look good and were originally installed. I didn't know that until now. Yes, the cooling of the exhaust tract is improved. When parking, less air circulates from the bottom up and the engine cools down more slowly. The air filter is mounted upright, so no problem. Thanks for reporting the fits. I will mount the sheet metal edges with adhesive rubber liner. Thanks also for the photos and the links!
01-19-2020, 10:58 AM | #13 |
Re: Engine pans
Using adhesive liner when installing the engine pans will cause the engine pans to be a pain to remove when necessary . Lock washers work well at holding the engine pans in place for me .
It has been said that engine pans help cooling by 15% . I feel that the pans help !!! The model A needs all of the cooling help that it can get . Fifteen percent may not be that noticeable . Any improvement in cooling is good . Last edited by Purdy Swoft; 01-19-2020 at 11:05 AM. |
01-19-2020, 12:34 PM | #14 |
Re: Engine pans
I think they help keep the engine compartment clean.
01-20-2020, 11:20 AM | #15 |
Re: Engine pans
I agree !!!
01-20-2020, 11:51 AM | #16 |
Re: Engine pans
My AA has the bolts still on the frame and remnants of the long gone pans still under the bolts. If I ever get to that point I plan to install new ones.
01-20-2020, 01:04 PM | #17 |
Re: Engine pans
An adhesive rubber liner may act as a noise reducer, but it may also act as an electrical insulator... The engine pans are an integral part of the the grounding system, and need to be connected firmly enough to make an adequate electrical connection.....
TallyHo, John B |
01-20-2020, 09:04 PM | #18 |
Re: Engine pans
The two places the engine pans bolt onto the oil pan are prone to cracking and breaking since the oil pan bolts are recessed a small amount inside the flange of the oil pan. I put a couple of small washers between the oil pan and the engine pan to keep the tabs straight when the bolts are tightened up.
Dave / Lincoln Nebraska |
01-20-2020, 10:34 PM | #19 |
Re: Engine pans
Use the extra grd strap from tranny top to the original ground location. Even if you have pans, it’s a better grd.
01-20-2020, 10:36 PM | #20 |
Re: Engine pans
31 Cabriolet 68-C, the best way to make sure the engine is grounded to the frame is to attach a wire to a bell housing bolt and connect the other end to the frame. Very simple to do and it works.
