Old 11-14-2016, 10:11 PM   #1
40cpe
40cpe's Avatar
Default air cleaner for a 94 carb
I've been searching for an air cleaner assembly for a 94 carb. All I've found is a K & N at autozone. I would rather have a paper filter. Anyone have a suggestion?
Old 11-14-2016, 10:48 PM   #2
38bill
38bill's Avatar
Default Re: air cleaner for a 94 carb
If your looking for a aftermarket type air cleaner check out Speedway Motors. O'brien Truckers also has some nice air cleaners that use a fabric type filter that should breath better than a paper element.
38bill is offline   Reply With Quote
Old 11-14-2016, 11:28 PM   #3
mhaim
mhaim's Avatar
I used K&N E-3330. Has lots of surface and doesn't look to bad. Had to make a special screw for extra height.
mhaim is offline   Reply With Quote
Old 11-14-2016, 11:48 PM   #4
Talkwrench
Talkwrench's Avatar
See if you can find a 55 air cleaner. however converting the 55 to a paper filter is a real pain. Think the filter I used was for a mini moke. The above might be easier.
File Type: jpg 13315452_10154218417983064_2925446511699253143_n.jpg (42.8 KB, 28 views)
Old 11-15-2016, 07:36 AM   #5
chap52
chap52's Avatar
LMC Trucks has a couple of options if you not trying to look original. http://www.lmctruck.com/icatalog/fa/full.aspx?Page=88
I found that the small one seems to restrict the air flow too much. But I am running dual 94's and they may be fine on a single.
