04-14-2019, 07:11 PM | #1 |
Model 59 Holley Carburetor - Is it an Economizer Valve or a Power Valve?
Recently there was a thread regarding this valve and exactly what it should look like. Can someone help me find this thread? The repair kits available today supply valves of differing shapes. What exactly should this valve look like and how can it be tested before using? Thanks for any help you can provide.
40larry |
04-14-2019, 09:56 PM | #2 |
Re: Model 59 Holley Carburetor - Is it an Economizer Valve or a Power Valve?
I don't have pictures, but if you're refering to the external valve, that is a spark control valve. Although it appears similar in appearance to a power/economizer valve, it has an entirely different function and will not interchange. the power (or economizer) valve is internal.
04-14-2019, 10:02 PM | #3 | |
Charlie Price has all the correct parts for your carburetor, he also has some excellent video instructions on youtube at: https://www.youtube.com/watch?v=kPq4WhD2s0Y This is part one of the 4 part series on rebuilding Holley carburetors.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 |
04-15-2019, 01:17 PM | #4 |
The later type Holley vacuum diaphragm power valves don't fit well in the older carbs but modifications can be done to the housing to make some later types work. Here is a link: https://www.jalopyjournal.com/forum/...valves.155818/ CharlieNY, here on the forum, makes a late type valve fit and seal like they should. Last edited by rotorwrench; 04-15-2019 at 01:33 PM. |
