09-20-2013, 07:18 PM | #1 |
Fuel Pump
I have a mechanical fuel pump (without glass) that has started to leak at the edge of the diaphragm. Per the Shop Manual instructions (pg. 103) I tightened the cover screws, to no avail. What have I done wrong, too tight?
Where can I get replacement parts for the fuel pump: screen (9365), upper gasket (9364), diaphragm-compatible with ethanol (9398?), and lower gasket (number=?)?
Joe/Ct "The older I get, the better I was" |
09-20-2013, 07:59 PM | #2 |
Re: Fuel Pump
Probably need new gasket. I get them from macs. If you want it fast napa has them.
09-20-2013, 08:10 PM | #3 | |
Re: Fuel Pump
That's a an easy pump to rebuild. The only bolt you may tighten too much is the one that holds the top cover in place. I've seen guys tighten that down so much as to cave the cover a bit and thereby allow vacuum to escape.
09-20-2013, 08:11 PM | #4 |
Re: Fuel Pump
Joe,
Well here goes....I make my own diaphragms and salvage the stems etc from defunct diaphragm assemblies. I use military grade viton that pumps straight alcohol....it is not cheap but it works. Charlie ny [email protected] |
09-23-2013, 10:57 PM | #5 |
Re: Fuel Pump
I have checked with all of the regular houses (MAC's, Drake, Carpenter, Job Lot, etc) and still cannot find a source for the screen (9365) and upper gasket (9364). Help!
09-23-2013, 11:28 PM | #6 | |
Re: Fuel Pump
Tell me if you will, if vacuum is allowed to escape, would you then have more, or less vacuum than you started with?
Alan |
09-23-2013, 11:39 PM | #7 |
Re: Fuel Pump
I have the screens and anything else you may need,i have all the variaus sizes need inside diameter of bowl and if a 2 hole job. 1 bigger hole and 1 smaller one and the gasket. Cork i have i know which one on that. ken ct PM please
09-24-2013, 07:49 AM | #8 |
Re: Fuel Pump
Ya got me
09-24-2013, 09:16 AM | #9 |
Re: Fuel Pump
