12-20-2014, 11:36 AM | #1 |
Is Positive Ground Better Than Negative?
I've been wondering about the positive vs negative gound question and why our old Fords were mostly (or entirely) positive ground. All my old Fords are wired with positive ground (except one) while my newer daily drivers are all negative ground. Why did Henry use positive ground in the old days, and why did he switch to negative ground later on?
Also, why did he wire some negative ground in the early 1940's? Specifically I have a Ford 9N tractor that is negative ground, and an 8N tractor that is positive ground. All of my Flathead V8 engines IIRC are positive ground. |
12-20-2014, 11:43 AM | #2 |
Re: Is Positive Ground Better Than Negative?
In electrical engineering circles of the day, it was agreed that the way the electrons flow made positive earth more efficient. When dealing with 6-volt systems you need every advantage you can get. Any form of degredation in the OEM system circuitry will lead to problems so they have to be maintained in top condition to work well.
The N series tractors ony have a rudimentary system so it would likely work just as well either way. |
12-20-2014, 12:14 PM | #3 |
It's not just Ford, a lot of the early cars used positive ground. Because electrons are negatively charged and the thought was the electrons move through the wire it was thought that electrical circuits should be wired so that the electrons could move from the negative side of the battery through the circuits to the positive ground. Over time it was determined that the concept of holes moving (an electron missing to leave a positive charge) worked for circuit design. This gets a little complicated as to what is really going on, but that is a somewhat cartoon version!
12-20-2014, 02:59 PM | #4 |
Positive ground is better if you want your battery gauge to work right. I found that out after I got my car back on the road that had sat for 31 years. Knew nothing of positive ground so when I put a new battery in I hooked it up negative ground just like all my other cars. Everything worked fine except the battery gauge worked backwards - showed charging when it was discharging and vice-versa. Knew no better until I had the engine rebuilt and the mechanic said, "Bet your battery gauge has been working backwards. . . . That's cause you've got your battery hooked up backwards."
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
12-20-2014, 03:20 PM | #5 |
I'm surprised that you could get away with that backwards hook up of the battery with no difficulties other than the guage working backwards. If that's the worst that it can do, I think that i'll try hooking up the battery backwards on my 1940 Ford 9N tractor, and see if that helps it start better than it currently does with the negative ground hook-up.
12-20-2014, 03:22 PM | #6 | |
Charlie Stephens |
12-20-2014, 03:37 PM | #7 |
I heard rumors back in the 50s that was because they all went to 12V so as not to confuse anyone they also went to neg ground. I said IT WAS A RUMOR noting in writing.
When I got my 34 5W in my avatar the P O was sooo thrilled because he had rewired it. Slight problem tho he used 12V cables & wires & neg ground. Did not change anything from 6V to 12V. He also placed the battery in the trunk behind the driver seat. Could not figure out why the battery wouldn't keep a charge & the halogen headlight were always dim. |
12-20-2014, 04:05 PM | #8 | |
you will need to polarize the generator, no big deal. Bob |
12-20-2014, 04:25 PM | #9 |
I have never seen a 9N Ford that was NOT Positive ground. Make sure you have a good shiny surface where the starter connects to the motor & use 00 battery cables (assuming your still 6 volts).
12-20-2014, 04:47 PM | #10 |
My coil worked just fine either way.
12-20-2014, 05:08 PM | #11 |
coils will get hot if there hooked up wrong
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
12-20-2014, 05:16 PM | #12 |
When I bought my 8N the previous owner had replaced the ground from the battery with a new cable( 12 volt skinny plastic covered,imported), I went and got a nice 1 in wide 1/4 in thick woven flat ground cable, now starts up in less than 1 full turn.
12-20-2014, 05:30 PM | #13 |
A long long time ago I read a British article that said it was better to have positive ground because somehow it helped prevent body corrosion. Many British cars were 12v/ PG. Judging from the many British cars I had in my youth, it didn't work.
'52 F-1, EAB flathead |
12-20-2014, 07:04 PM | #14 |
I also had 2 Triumphs and a Jag all 12 volt and positive ground. Like Ross F-1 said, didn't solve the rust problem. The Brits called it positive earth.
12-20-2014, 07:22 PM | #15 |
12-20-2014, 08:00 PM | #16 |
Is there an easy way to tell if an old Ford is still positive or negative ground if you acquire one and the battery is missing? I bought an old Model A and don't know if someone converted it to negative ground or not.
Matt 24:36-41 |
12-21-2014, 03:24 AM | #17 |
34pickup, If the battery cables are still on the car, just see which one has the larger opening for the battery post. The positive post on the battery is bigger than the negative post so is easy to see which is which.
12-21-2014, 07:39 AM | #18 | |
Maybe coincidence but an observation. Over here (Britain) there are far more mid to late 60's and earlier cars on the road than late 60's through to mid to late 80's, these later cars dissolved pretty much while you looked at them! So possibly some truth in that? As I said, just an observation. Martin. |
12-21-2014, 07:46 AM | #19 |
I have always understood the reasoning to be that the battery was less susceptible to corrosion and the old cloth covered wires were less susceptible to static discharge thereby causing connection/corrosion problems where wires touch metal.
Tommy |
12-21-2014, 08:18 AM | #20 |
If there was a significant advantage to pos earth (ground) over neg earth, then all manufacturers of cars would have taken that advantage. You wouldn't universally switch over to negative earth if positive earth gave an advantage.
Mart. |
12-21-2014, 10:25 AM | #21 |
The amount of efficiency difference is slight with 6-volt but the voltage level is also very low. With 12-volt, the higher voltage makes the efficiency difference almost nil.
It's a proven fact that a coil with the wrong polarity does lose efficiency. A lead pencil or one of the little polarity checkers can find out pretty easy. Just switch the leads. If a person has an old car that still has an old can type coil that is marked DIS & IGN (or BAT) then it's a safe bet that it was positive earth. With terminals marked + or - then it's a crap shoot. the ignition will still work backwards but it won't work as designed and will lose a little of its punch. |
12-21-2014, 10:56 AM | #22 |
Any of those amp. meters that have the wire pass through a sense loop, can be reversed by running the wire the opposite way. Current passing through the wire creates a circular magnetic field, which rotates in a certain direction, in relation to the current flow. When you turn the wire the other way, the magnetic field rotates in the opposite direction. The meters just deflect the indicator hand depending on which way the magnetic field rotates.
12-21-2014, 01:39 PM | #23 |
Coil polarity explanation here: http://www.chicagolandmgclub.com/tec...neral/574.html
12-21-2014, 03:41 PM | #24 |
The reason correct polarity at the coil should be observed is that the primary and secondary windings are connected at the high voltage outlet. When system polarity is reversed from positive to negative ground, the connections at the small terminals on the coil should be swapped, as well. The principle that current flow was from negative to positive was believed to be more desirable probably came when Edison and Tesla were locked in a duel to see whether AC or DC would be the chosen utility method. Tesla won, of course, which is a good thing because transformers could be used. The ignition coil is a transformer driven by the distributor points.
