07-10-2015, 11:04 PM | #21 |
Re: Leaning radiator of tudor
Checking closely I think I have found the problem. See the frame in the photo, just aft of the front crossmember. How disappointing. All measurements are the same from the rear forward up to the cross member. Is there any way possible I can rig a system to straighten this myself? Any suggestions??
07-10-2015, 11:34 PM | #22 |
07-10-2015, 11:40 PM | #23 | |
Bring it down to a body shop with a frame straightener. Tell them they can use pictures of the car in their advertising if they give you a break on the price.
09-07-2015, 09:54 PM | #24 |
Just a follow up, interesting to see the progress of solving this dilemma. Discovered the frame was bent just about ten inches aft of the pass. Side cross member attachment. Frame shops were reluctant to even give me an estimate let alone do the job. So..... Found an article via TFB on how to straighten a frame. Yea verily, 14' of six by six, two substantial sections of chain a six ton hydraulic jack and less than one hour, mostly spent rigging and all was copasthetic, removed only the right front fender and headlite bar. Just installed the hood today and all looks well. Nice to know there are guys who got my "A back". Interesting that things we would tackle without a second when younger seem quite daunting as we get older and "wiser"???
09-07-2015, 10:24 PM | #25 | |
Glad to see you got it done! If it were me I would drive the fixed car car down to the frame shop and say, "look what I did with some chain and a jack. And you could not do it with all your fancy equipment." But that's just me. I felt a little hot just reading your post about how they did not want to work on it. Any wonder why we are becoming more and more a throw away country?
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 09-07-2015 at 10:54 PM. |
09-07-2015, 10:41 PM | #26 | |
09-07-2015, 10:54 PM | #27 |
Good to have followup and learn the outcome.
Bob |
09-08-2015, 08:31 AM | #28 |
I finished mounting the radiator on my 190A restoration not long ago, and it took several iterations of shimming and rod adjustments to get it looking good.
Shimming rotates the radiator side to side, that is, clockwise or counterclockwise. The rods tilt the top of the radiator fore & aft. You will also find that the attachment holes in the frame for the radiator allow some adjustment, but not a lot. Do the shimming first using rubber pads under the mounting feet of the radiator. Take the radiator shell off to get the shims into place without loosing your temper. Check the result with the radiator shell bolted into place. Watch the clearance of the shell at the front radiator splash shield. In my case, I used the firewall as a reference guide to determine if the radiator shell position was good. Shimming the radiator may affect the fit of the hood. If this occurs, correct the alignment by shimming the aft hood hinge fitting, and by adjusting the radiator support rods. The radiator I have is a reproduction, and the fit of the original radiator shell was horrible. I slotted all of the shell's mounting holes in the radiator. Good luck with this fix, and I hope your experience will be easier than mine was.
Bob Bidonde |
09-08-2015, 05:14 PM | #29 |
Tweaking the frame I would not neglect to check your toe-in
