Old 05-09-2013, 06:21 AM   #1
Phred
Phred's Avatar
Default Tire Tubes
If the proper sized tube were not available, any real world experiences on whether a 19" tube would perform satifactorily in a 21" tire or vice-versa?
Phred is offline   Reply With Quote
Old 05-09-2013, 06:40 AM   #2
QGolden
QGolden's Avatar
Default Re: Tire Tubes
"Back in the day" I put tubes in tires that were an inch or so "too small" with no problem. I think the quality of tubes today is not what it used to be, and some may say that the extra stretch could be detrimental. I have heard a Motorcycle tube can be used on a 21. I am sure someone here will tell you if the valve stem is in the right spot. 21 is a common front wheel size amongst the Harley set.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 05-09-2013, 10:09 AM   #3
Houston Rodder
Houston Rodder's Avatar
Not sure about the answer to your question but I have used tubes that were a little smaller than required in 19" tires. On a long trip in my coupe I blew two old tubes and was forced to quickly source a new one. Tractor Supply carries close sizes that got me on my way.
Houston Rodder is offline   Reply With Quote
