05-08-2013, 03:36 PM | #1 |
downdraft carb
I'm putting a downdraft intake with a #94 carb on my Model A. The motor has a "B" cam and a 5.5 Snyder's head. What kind of pump is a good buy and what kind of fuel regulator and what pressure should I run? thanks
05-08-2013, 03:45 PM | #2 |
Re: downdraft carb
Mike ;
You can do a search and get some good info on this . |
05-08-2013, 04:24 PM | #3 |
Re: downdraft carb
Under 3 psi. Napa has a "low pressure" electric pump that is rated at I think 4 psi, but mine is mounted down inside the frame and the pressure at the carbs is between 2.5 to 3 without a regulator. That is with 5/16 inch steel tubing with hose connectors at the pump and carb ends to allow for vibration.
05-08-2013, 09:13 PM | #4 |
Re: downdraft carb
mr. gasket makes a 2-3# pump , no regulator needed . excellent pump . ive been using one for a few yrs now .
Part No. 42S Specs: 2-3.5 PSI, 42 GPH. ***** this is a 12vdc but they do make a 6vdc
V4f |
05-08-2013, 10:36 PM | #5 |
Re: downdraft carb
Checked, could not locate a 6volt on their site.
05-09-2013, 05:30 AM | #6 |
Re: downdraft carb
05-09-2013, 08:03 AM | #7 |
Re: downdraft carb
My brother did the same thing on his T.
05-10-2013, 12:24 AM | #8 |
Re: downdraft carb
Snyders sells the appropriate regulator for a Stromberg downdraft. 1 1/2-2 psi.
05-10-2013, 12:52 AM | #9 |
Re: downdraft carb
Holly makes a pres. reg. for the Holly 94. It comes preset at 2.7 PSI. Be sure to use a pres. gauge to be certain of the pressure. Summit part # HLY-12-804.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls '41 Fordor Deluxe / 2-duece flattie '66 1/2 Dodge Charger '14 100th Anniversary Challenger Limited Edition. Semper Fidelis |
