Old 12-05-2017, 04:41 PM   #1
petehoovie
petehoovie's Avatar
Default '34 Pedal Pads
It's time for the 83 year old brake and clutch pedal pads on my '34 to be replace. I find that removing (unscrewing) the the old pads by hand is not an option for me. To those of you who have done this job, what tool did you use? I'm thinking that a strap wrench would be appropriate for this job. I'm concerned about possible damage to the rubber on the new pads I purchased when tightening them down....
Old 12-05-2017, 04:45 PM   #2
JSeery
JSeery's Avatar
Default Re: '34 Pedal Pads
Strap wrench is what I would use.
Old 12-05-2017, 04:45 PM   #3
VeryTangled
VeryTangled's Avatar
Hi Everyone. I had some tough ones too. A dab of penetrating oil helped tremendously. Got 'em by hand afterwards. Tightened by hand going back on.
-Jeff H
Old 12-05-2017, 04:53 PM   #4
MGG
MGG's Avatar
I also tightened the new ones by hand. They have not come loose yet.
MGG is offline   Reply With Quote
Old 12-05-2017, 05:02 PM   #5
DavidG
DavidG's Avatar
Hand tightening should be sufficient. If in doubt, use Loctite.
Old 12-05-2017, 05:22 PM   #6
JSeery
JSeery's Avatar
Question, how does he do it by hand if he states that is not an option for him?
Old 12-05-2017, 06:08 PM   #7
petehoovie
petehoovie's Avatar
I see that the new pads I purchased came with a thick split lock washer. I don't know if the original pads use this split washer as I have not removed them yet. Can someone recommend a quality strap wrench? It seems to me that it will be difficult to collapse this washer by hand tightening the pad without a tool. Using Loctite as DavidG suggested and eliminating the split washer might be the way to go....
Old 12-05-2017, 06:41 PM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
Mike, the original pedal pads had a tapered thread that locked in place on the taperd female threads on the pedal arms, when hand tightened, requiring no lock washers. Today's repros have a straight thread making a lock washer or loctite more of a necessity.
I've always used an old strap wrench that has a leather strap to remove or install pedal pads. This is a well made "hand me down" tool. No idea who made it.
John
Old 12-05-2017, 07:13 PM   #9
DavidG
DavidG's Avatar
JSeery,
With respect, he referred to removal of the old by hand not being an option, not to installing the new ones by hand.
Old 12-05-2017, 08:49 PM   #10
Talkwrench
Talkwrench's Avatar
Just a word of warning, I did do that without thinking and when it came to screw the pad off it wouldn't budge! I had to drill the centre and "easyout' the bastard..
Old 12-05-2017, 09:33 PM   #11
DavidG
DavidG's Avatar
There are several types of Loctite, including those that don't effectively weld the threads together.
Old 12-05-2017, 10:05 PM   #12
JSeery
JSeery's Avatar
JSeery,
Thought that is what I was answering? Guess this question is over my head!
Old 12-06-2017, 01:46 AM   #13
petehoovie
petehoovie's Avatar
JSeery - You done good. You answered my question. I'll need a tool (strap wrench) to remove the pads....I might not need a tool to install the new ones. That is, I might be able to install the new pads by hand. Thanks....
Old 12-06-2017, 03:07 AM   #14
Mart
Mart's Avatar
No need for a strap wrench if you don't have one..
Take a piece of scrap wood, roughly 3 inches wide and 3/4 thick and 12" to 14" long. I used a piece from a broken up pallet.
Clamp the wood to the face of the pedal pad with 2 G clamps.
Use the leverage of the wood to turn the pedal pad. Once you have broken it loose you should be able to continue by hand, or reapply the wood for a second go.
The wood will key into the rubber (or remnants of the rubber) without damaging it.
I used the above on some 41pu pedal pads, one did undo by hand, the other was tight and the method above did the trick. I don't have a strap wrench.
The pedals have a pipe thread, you should be able to tighten them by hand tight enough that they will not come undone. If not, the above method can be used to tighten them.
32 pedal pads have a straight 1/2"-20 thread and require a nut and a lock washer. If you are trying to fit a 32 pad to a 33-up you might have a problem.
Mart.
Old 12-06-2017, 06:20 AM   #15
PeteVS
PeteVS's Avatar
Mart.
Pretty sure that '32s have a 7/16-20 thread.
Old 12-06-2017, 07:15 AM   #16
Mart
Mart's Avatar
^^ Yeah, could be, I was going by memory.
Thanks for the correction.
Mart.
Old 12-06-2017, 08:18 PM   #17
Ggmac
An oil filter wrench ( small steel banded one ) worked for me . Already had it in the tool box .
Old 12-06-2017, 08:41 PM   #18
petehoovie
petehoovie's Avatar
Good idea! - That might work. Now, to search for one in my garage....
