09-08-2017, 06:06 PM | #1 |
Weber carb
Looking to fit a weber carb on my A. Anyone know which model fits with the intake manifold? I happen to have a weber from my 69MG that is no long on the car and I would like to just use this one. Thanks
09-08-2017, 06:22 PM | #2 |
Re: Weber carb
32-36 buy from AZ Model A , also has the intakes,
09-08-2017, 06:23 PM | #3 |
Re: Weber carb
Usually the Weber kit sold from the vendors have a 32/36 DGV. You might want to search around for jets used by others. Here is one place to look, read the dyno sheets. He has jet sizes listed on the sheet for a Weber and that depends on all the other modifications besides just the Weber.
http://www.modelaparts.net/dynosheet...ynosheets.html |
09-08-2017, 07:02 PM | #4 | |
Re: Weber carb
09-09-2017, 02:30 PM | #5 | |
Re: Weber carb
09-08-2017, 06:55 PM | #6 |
Re: Weber carb
09-08-2017, 07:01 PM | #7 |
Re: Weber carb
I like the DGV 5A which has the manual choke.
09-08-2017, 07:01 PM | #8 |
Re: Weber carb
denis4x4, does this look familiar? I can't figure out where it goes on my Weber.
09-08-2017, 11:20 PM | #9 |
Re: Weber carb
I have been installing a couple of Carter-Webers on my Model A. There are manifolds available. I'm in process of building a dual carb manifold for mine. You can adapt a 3 bolt to 4 bolt carb base fairly easy. The carburetors I bought from http://www.langdonsstovebolt.com/store/
09-09-2017, 04:21 AM | #10 |
Re: Weber carb
I've bought parts from this place...
http://www.webercarbsdirect.com/32-3.../22680.005.htm Check out their price, and free shipping. I like the Langdon air cleaner, but not sure it will fit on my 29 Tudor. I had to do some modification to the air cleaner base on mine, rectangular shape so that it wouldn't rub against the hood. |
09-09-2017, 12:47 PM | #11 |
Re: Weber carb
Here is my air cleaner
