Old 05-06-2015, 05:54 PM   #1
37coop
37coop's Avatar
Default 51 F1 brake pedal ....lower?
Hi guys , my 51 f1 truck .After an accident at work resulting in a spine op my right leg is a little weak on lifting, the problem is I sometimes find it an effort to lift the leg high enough to apply the brake pedal as you know its higher than a normal everyday car ,any ideas to lower the pedal a little without potential danger ? I,v even thought of cutting a small section off the pedal upright to shorten it and welding, I dunno just a thought , any ideas ? thanks Jim.
37coop is offline   Reply With Quote
Old 05-06-2015, 06:14 PM   #2
George/Maine
George/Maine's Avatar
Default Re: 51 F1 brake pedal ....lower?
To shorten the pedal is not a good idea you may need what you cut off to stop.
Find a car with power brake and low pedal it will be a cowl mount.
George/Maine is offline   Reply With Quote
Old 05-06-2015, 06:15 PM   #3
RandyZ
I have the same problem. What I did was glue a 1" rubber to the normal floor mount bumper. Then I re-adjusted the brake rod to suit. I know that this takes away some of of the potential brake pedal travel, but if you have a firm pedal that is still 2" off the floor, you should be okay.
RandyZ is offline   Reply With Quote
Old 05-06-2015, 06:23 PM   #4
37coop
37coop's Avatar
mmmm,its the "should" part that is the problem for me ,but worth a thought thanks Jim.
