Old 08-25-2012, 06:37 AM   #1
BILL WZOREK
BILL WZOREK's Avatar
Default Final report on Blast cabinet Gloves
I think we have found a winner as far as Blast cabinet gloves go.
if you remember I asked for a good Quality glove. as the ones I was using the quality went to S**T & I could only get 1 week use before they had to be replaced.
So on Yoyodyne sugestion I tryed one from -Zero he was correct they are "GREAT" Started using on 6/30/12 today is 8/25/12 Darn close to2 month's use and to look at the glove it is hard to see any ware at all.
So the $35.00 was well spent.
With this test I did nothing different then I was before trying to be as fair as I could be. VERY PLEASED
BILL W
BILL WZOREK is offline   Reply With Quote
Old 08-25-2012, 09:54 AM   #2
ken ct
Default Re: Final report on Blast cabinet Gloves
Bill is Zero the name of the co.?? more contact info,having the same troubles. ken ct.
ken ct is offline   Reply With Quote
Old 08-25-2012, 11:07 AM   #3
Fordors
http://www.cylinderheadsupply.com/zeblcagl1.html
ken ct, here is contact info for gloves.
Fordors is offline   Reply With Quote
Old 08-25-2012, 11:21 AM   #4
BILL WZOREK
THANKS Fordors !
BILL W
Old 08-25-2012, 11:24 AM   #5
ken ct
Thanks fordors,appriciate it. ken ct.These gloves from Tip dont hack it.
Old 08-25-2012, 08:57 PM   #6
Yoyodyne
Yoyodyne's Avatar
Glad I could help, and glad it worked for you.
Yoyodyne is offline   Reply With Quote
Old 08-26-2012, 01:40 AM   #7
ken ct
Thanks, ordered a set last nite to try. ken ct.
Old 12-12-2012, 07:26 PM   #8
BILL WZOREK
Catastrophic failure on the Gloves !!!!!!
NO just kidding the stitching where the arm & glove connect ,pulled apart But the glove is still going great my Daughter sewed in up and it is back in cabinet this afternoon.
Old 12-12-2012, 07:43 PM   #9
russcc
I use heavy duty, long wrist gauntlet rubber gloves from the commerical fisherman supply store. had one pair of "Boss" gloves that lasted 5 years. New ones, going on 3 years.
Old 12-13-2012, 03:08 AM   #10
ken ct
Got them Bill but havent installed yet,might as well run out the Tip ones i got first. Any solution to the stitching problem. Maybe cover stitching with duct tape?? ken ct.
Old 12-13-2012, 03:10 AM   #11
ken ct
Name and # for these "BOSS" gloves you mention??? ken ct thanks
Old 12-13-2012, 05:53 AM   #12
flatmotor40
flatmotor40's Avatar
What blast gun do you use and is it a siphon or just pressure.Those ceramic ones don't hold up at all
flatmotor40 is offline   Reply With Quote
Old 12-13-2012, 08:43 AM   #13
ken ct
I use a tip S25 ithink. and use the $50 nozzles in it. I get a yr or more out of them. ken ct.
Old 12-14-2012, 06:08 AM   #14
flatmotor40
Thanks Ken I think that is the carbide nozzle.Do you use sand or what in your blaster for media.I have bought sand from the rent-all place in town but someone told me to use Black magic or something like that from Northern tool.They say it works better Thanks Flatmotor40
Old 12-14-2012, 08:04 AM   #15
BILL WZOREK
Ken my next set I will have them stitched by my Wife or Daughter 1st.
BILL W
Old 12-14-2012, 08:10 AM   #16
BILL WZOREK
flatmotor
I use the Black magic it is a little more aggressive then sand & does not powder or turn to dust as fast it does not leave a satin finish but I am not looking for that type finish.
BILL W
Old 12-15-2012, 06:05 AM   #17
flatmotor40
Thanks I"ll go up to Northern and get a couple bags
Old 12-15-2012, 06:58 PM   #18
Yoyodyne
Yoyodyne's Avatar
I just looked at mine and they have no seam between the sleeve and glove. Mine are in 2 halves, stitched along the length and around the edges of the fingers, like regular gloves. Rubber on the outside, cloth lining on the inside. I'm pretty sure mine are no more than 2 years old, and this is how they've been for years, so either one of us has another brand or Zero changed how they make them. I buy mine from Precision Finishing and I just assumed they were Zero because that's where I bought my Zero cabinet.
Next time I buy some, I'll ask, but it will be a while.
Link to Precision Finishing - http://www.precisionfinishinginc.com...ufacturers.php
They handle quite a few mfgrs, could easily be another brand.
Old 12-15-2012, 07:30 PM   #19
ken ct
I use #4 or 5 glass beads. Ive used black magic at work and its very,very aggressive and would not be good for carbs and such. ken ct. yea i couldn't think of the name of the carbide nozzles.They last a long time. I usually put a "O" ring kit in the gun a couple of times a yr. ken ct.
Old 12-16-2012, 06:02 AM   #20
flatmotor40
Thanks Ken I just ordered a s25m gun and carbide nozzle fro TP Tools.For aluminun or soft stuff I have a 55 gal drum of plastic ground up buttons that we used on aircraft skins when I worked at the airlines
