07-10-2010, 09:16 PM | #1 |
Coolant additives
07-11-2010, 07:50 AM | #2 |
Re: Coolant additives
I was using 30% glycol and water wetter. In 95 deg temps the car ran 180 at cruise under load.
Yesterday I tried distilled water and water wetter. 95 deg-170 under load. This is with a clean engine and radiator.160 thermostat. |
07-11-2010, 04:37 PM | #3 |
In the spirit of discussion, I'll jump in: Buy this stuff if any of it makes you feel good, but do yourself a favor before spending: Make them justify why you should spend your money with a good comparison - which this IS NOT. First, the Specific Heat of water is 0.998 cal/g *C, ethylene glycol (most antifreeze base) is 0.574 cal/g *C. This means EG will transport heat about half as good as water. Note the comparisons using just water showed the best results almost exclusively. Duh. Looking at their data, the "worst condition" car, 50/50 Honda antifreeze/distilled water mix, means all testing should have been with the same base mixture but with the different additives. I think there are obvious reasons why they failed to do this. Also, their mixtures of antifreeze and water are all over the map: Fifty/fifty, 70/30, 30/70. Finally, the ambient temperature was dropping as the testing progressed, stacking the odds in favor of the additives. These may be the best products since sliced bread, but the testing team wouldn't last a week in a real lab. If you really want to know whether any of these products work, drain your Model A engine and fill it with clean distilled water. Take data and then add your favorite Moose Juice additive and retest, keeping conditions as close as possible for each test. When you're satisfied the product really works, buy it and endorse it. Sorry for being such a skeptical nerd - I used to get paid for doing this .
07-11-2010, 05:53 PM | #4 | |
I ordered some DEI radiator relief for $22 from Summit Racing and will add some when I get it and report the results. The temperature around here in SE Texas doesn't vary much. It is 93-95F every day from May 15-Oct 1. I don't want to run just water as it doesn't have the corrosion additives, etc of anti-freeze. I have a brand new Brassworks radiator already. I'm about to receive a newly rebuilt inserted engine from Pete's Automotive in Albaquerque, NM with lots of goodies, new Brierly cam, new Chinese crankshaft, new inserted rods, and Brumfield head. So I thought I'd do a little cheap experimentation with coolants. I know the biggest factor in lowering coolant temperature will be with the high compression head as it is much more thermally efficient. I would have put the Brumfield head on the current engine but it didn't look like I could get the studs out without putting the engine out of service. |
07-11-2010, 06:15 PM | #5 |
If I run antifreeze, my temp gauge reads about ten degrees hotter than if I use tap water. I don't know the exact numbers because I bought my temp gauge at Tractor Supply and it only has markings for 130, 190, 250 and 280 degrees, but it was cheap and doesn't require any current. I put the probe in the upper radiator hose and am very pleased with it.
07-12-2010, 01:18 AM | #6 |
The jury is out, just tried this formula |
07-12-2010, 07:21 AM | #7 |
I believe that the Water Wetter and similar additives are a waste of money in the vintage car radiators. There are simpler solutions without cost. I have tried these in a vintage MG and my Model A. Neither did anything in a controlled situation.
In the case of the Model A, over heating was cured by dropping the percentage of antifreeze from 50 to 25 or less. Use anti corrosion additives if you do this. |
07-12-2010, 08:13 AM | #8 |
07-13-2010, 05:12 PM | #9 |
Just for the record, I found Water Wetter on sale at Advance auto parts this week 7-13-10 about 2 dollars off. Its hard to pay 10 bucks for 12 oz.They say 1 bottle per 3 gal of cooling. I have been using it with Distilled water have been running cool, but also have new HD 10 fin Radiator.
