07-11-2022, 02:02 PM | #81 |
Re: Engine temp rises when I get to cruise speed
Hey Brassworks/Lee - couple points:
1) Given that this whole thread references cooling/heat issues on the highway at higher speeds, how would pusher/puller or any fans actually help that situation? I completely understand their usage when the car is not moving or moving slowly (idling, stop n' go or very slow-speed situations) - but do not see how they'd help with a cruise situation at higher speeds? Please educate us on this particular part of the conversation. 2) Radiator Front Pan - he put that back on awhile ago. Thanks for getting on the thread . . . your comments are not "piling on". B&S Last edited by Bored&Stroked; 07-11-2022 at 04:13 PM. |
07-11-2022, 04:10 PM | #82 |
Funny about the term piling on. Seems that few posters even bother to read through previous postings before jumping in blindly at the end. The OP posted about installing the lower pan way back at post # 40.
Another thing about suppliers who obviously have considerable knowledge, why don't they make suggestions to their clients on best product for the application? I know many do, but many do not also.
Alan |
07-11-2022, 04:30 PM | #83 | |
07-11-2022, 04:46 PM | #84 | |
I'm not taking the bait.
Alan |
07-11-2022, 05:59 PM | #85 | |
There are suppliers of products and manufactures who make custom products. Your question/observation is likely to get two different answers for obvious reasons. |
07-11-2022, 06:13 PM | #86 | |
I missed the post where he put the panel back on. Most radiators are designed to meet the pan which, with the tank being flush to the core, and this prohibits advancing the core forward for a thicker core. We can build thicker radiator cores for notched pans and construct stepped/cantilevered headers to go over the top of un-notched pans. |
07-11-2022, 06:44 PM | #87 | |
Nice to know about some of the 'options' to fit bigger radiator cores into constrained places. I can see how this might really help in some situations. I'll ponder this when I'm ready (finally) to have you guys build a custom radiator for my car. I think we'd all like to see his problems solved and for him to have a cooler running engine under all conditions - hopefully we'll get there soon. B&S |
07-11-2022, 06:59 PM | #88 |
Has anybody used the new bob drake 5 fin water pumps designed to flow much more water
with spectacular results????? |
07-12-2022, 05:17 AM | #89 |
Thanks to all that are responding to this post.
First off Lee I think all of this could've been avoided if you offered me a larger core. I did tell you this was for a supercharged flathead motor. I assume you know that flatheads have cooling issues without a supercharger so I'm a little baffled as to why this was not offered to me. As the expert, you should've told me or at least offered a suggestion that I needed the bigger core. Second, I'm definitely not going to run two fans to try and solve the problem. Third, I will try removing the shroud and fan, but I already explained to you that the fan motor is connected to the shroud so the motor can't be taken off and installed. I would have to go back to a pusher fan which we already know did not do the job. If you think the puller will do a better job than the pusher, I can try to fabricate some brackets to get it mounted. Tell me how far the fan blades need to be from the core. I have an older puller fan that may be too big, but I could also see if I could get that to fit. I don't want to run the car without any fan with the coolant mixture I have in there now which is mostly water. I'm concerned with boil over. It seems to me that the radiator itself is not doing the job. I'm open to suggestions as to how we get this corrected. |
07-12-2022, 07:36 AM | #90 |
You'll surely need enough 'fan' to keep the engine cool at idle and at slower speeds. What I can't tell you is whether or not a combination of a fan/shroud (potentially restricting air flow at higher speeds) is compatible with achieving maximum air flow at cruise speeds - and that your radiator core has enough capacity to cool the engine with the amount of air going through it (with fan installed).
Once you pull the fan/shroud and run without ANY fan (at cruise speeds), you'll have another data point to apply in the design of a potential solution. Unless you're experiencing a lot of fan restriction at cruise speeds, my guess is that you'll need a bigger core that can dissipate more heat. Time will tell . . . best of luck! B&S |
07-12-2022, 07:59 AM | #91 |
Hey Guys,
I’ve been following this thread from the beginning. Here’s my take. Jrvariel48 has put in hours and hours of labor doing his his due diligence in trying to find the cause of the overheating problem other than just a faulty radiator. Instead of continuing to find fault with Jrvariel48, it’s time for Lee at Brassworks to step up with an immediate solution - a new larger radiator. It’s the right thing to do. Richard |
07-12-2022, 08:01 AM | #92 | |
07-12-2022, 12:00 PM | #93 |
I read somewhere that if the coolant flows too quickly through the radiator it doesn't have time to cool. Maybe the design of the aluminum radiator slows down the flow. Could that be happening here?
07-12-2022, 01:18 PM | #94 |
The “coolant flows too quickly to cool” myth will never die.
07-12-2022, 03:14 PM | #95 | |
07-12-2022, 03:15 PM | #96 | |
Thank you Joe |
07-12-2022, 03:17 PM | #97 | |
Thank, Joe |
07-12-2022, 03:19 PM | #98 |
Thanks again to all the responders!
I'll try to get the fan/shroud off this weekend if possible. and get another fan installed without a shroud to see how we do. I'll post the results as soon as I can. Thanks, Joe |
07-12-2022, 03:33 PM | #99 | |
You only need the fan (s) for traffic or low speed. Other than that they are junk in the way. Brassworks knows this no doubt in my mind. Anything other than removing radiator to install correct core is just wasting time. Sorry calling it how it is. Your blown engine still (respectfully) makes little hp. And with correct core will run very cool as even with blower added BTU,s it should be easy to cool. Just trying to help with my many years of experience. (I have been wrong before but doubt it in this case). I believe it’s time to stop wasting energy and correct the problem. Cheers mate. Tony |
07-12-2022, 03:40 PM | #100 | |
When I was running my 258 CI flathead with a 671 GMC blower combination on the street when I felt the need to beat on the engine I would use 100NL gas from the local airport. I had lots of street miles on that engine in the thousands like yours. That 258 cube engine powered my Land Speed Lakester race car. When I converted the Lakester to a Rear Engine Modified Roadster for testing I used that little old 258 engine. Testing on a runway in Maine resulted in a speed of 171 MPH the record on the salt flats at the time was 138. Still to this day I do not use any ignition retard with the race engine combination I can tell you the boost seen with the blower combinations I run are well over 10. My flathead and ARDUN blower street combinations also put out boost higher than 5 lbs with no ignition retard being used. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
