Old 03-26-2023, 09:57 AM   #1
russonator
russonator's Avatar
Default Service Letter for '57 E-code passenger car
A reputable source once told me about the existence of '57 Ford Service Letter for E-code (dual quad) passenger cars. It advises cutting an inch off the oil fill pipe to gain better clearance between the breather cap and air filter housing. Is anyone familiar with this Service Letter or know how I can obtain a copy?
Thanks in advance,
Russ
"In theory, there is no difference between theory and practice. In practice, there is." (Yogi Berra)
russonator is offline   Reply With Quote
Old 03-26-2023, 03:00 PM   #2
Hot Rod Reverend
Hot Rod Reverend's Avatar
Default Re: Service Letter for '57 E-code passenger car
Me too - just purchased this gem of an original setup!
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 03-26-2023, 04:49 PM   #3
mercman from oz
mercman from oz's Avatar
Hot Rod Reverend just purchased this E-Code Dual Quad Air Cleaner. Like russonator, he is also looking for the Service Letter for E-Code Passenger Cars.
Old 03-26-2023, 05:16 PM   #4
KULTULZ
KULTULZ's Avatar
Exclamation Re: Service Letter for '57 E-code passenger car
Thanks in advance,
Russ
Now this is interesting. I never heard that but it may be. You know I am sure there is a special valley pan for the E-CODE.
I shall return (it took MacArthur how long?).
You may also want to ask over @
- http://forums.y-blocksforever.com/Default.aspx.
Now the deal is if you find the answer over there, you return here and post the answer.
KULTULZ is offline   Reply With Quote
Old 03-26-2023, 05:28 PM   #5
russonator
russonator's Avatar
Happy to oblige. There are still quite a few who know the T'bird dual quad set-up inside and out; not so many for the passenger cars. Thanks, KULTULZ.
Old 03-26-2023, 06:27 PM   #6
KULTULZ
KULTULZ's Avatar
Question Re: Service Letter for '57 E-code passenger car
Can you measure your tube ... ... er, oil filler tube?
The OEM 1954-57 pan filler tube was 9.06" H
The OEM 1955/57 BIRD and 57 S/C tube was 7.56" H
The OEM 1957 FORD/BIRD E-CODE tube was 6.48" H
You pan does have a depression under the intake plenum?
Last edited by KULTULZ; 03-28-2023 at 02:33 PM. Reason: APPLICATION YEARS CORRECTED
Old 03-26-2023, 09:00 PM   #7
Hot Rod Reverend
Mercman from Oz is right, and I gotta say... I have the best kind of wife a man could ever have. She had no problem with me heating up the air cleaner housing IN THE KITCHEN OVEN before I brought it back to the shop for paint. She said, "Why not, you've got that thing as clean as a whistle - ain't going to hurt anything." When I told the dear lady that after our move to Lancaster, CA we will be only 40 minutes from El Mirage and land speed racing, she said, "That sounds like fun, maybe you can take your car out there too." Then I explained the deal on land speed racing, top speed, etc. My wife quickly replied, "I don't know about all that!" with her hand on her hips. She's a gem!
Kultulz - most of my parts are already loaded in boxes on pallets for the trip out west. It will be a while before I can measure for you.
Old 03-27-2023, 02:39 AM   #8
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Service Letter for '57 E-code passenger car
Oh, I am sorry Reverend, I meant that for russonator. But your measurement when possible will confirm.
THANX!
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
Old 03-28-2023, 12:17 PM   #9
russonator
russonator's Avatar
Well, I managed to get hold of the original source of my information. Felix Natoli, who is a walking encyclopedia on Y-blocks and especially the dual quad variety, dug up Product Service Letter P-351 dated July 16, 1957. Item #10 (attached) deals with the subject at hand.
Old 03-28-2023, 02:15 PM   #10
KULTULZ
KULTULZ's Avatar
Appreciate the info. Had no idea.
Was your filler cap hitting the ACL?
Old 03-28-2023, 03:16 PM   #11
russonator
russonator's Avatar
No, KULTULZ, the cap doesn't contact the housing. It's just a little awkward when removing the cap with the housing in place.
Personally I'm not going to perform the workaround described. Just wanted the Ford documentation that things are a little tight in that area.
By the way, and to answer your earlier question, the tube length conforms to the spec you gave.
Old 03-28-2023, 06:32 PM   #12
mercman from oz
Daniel's this E-Code Dual Quad Air Cleaner getting cooked.
Old 03-28-2023, 06:33 PM   #13
mercman from oz
Product Service Letter P-351 dated July 16, 1957. Item #10 - russonator
Old 03-28-2023, 08:30 PM   #14
scicala
scicala's Avatar
I've bought E code 2x4 stuff from Felix before. Good stuff.
Sal
scicala is offline   Reply With Quote
Old 03-29-2023, 02:59 AM   #15
KULTULZ
KULTULZ's Avatar
THANX for that info!
Old 03-29-2023, 07:10 AM   #16
russonator
russonator's Avatar
Sal
Felix has provided me the correct accelerator return springs, distributor advance vacuum line, and choke tube insulators, along with a good deal of sagely advice. He's a marvel at close to 90 years of age.
Old 04-15-2023, 06:16 PM   #17
russonator
russonator's Avatar
Just thought I would update this thread with today's interesting discovery. While the factory oil fill pipe on a dual quad passenger car does accommodate the standard black breather cap, it is too long to allow the larger chrome breather cap to fit under the air cleaner housing. I surmise this to be the genesis of the service letter cited above. I had switched out my black painted valve covers for the finned aluminum ones, and because these are part of the engine dress-up kit I thought I should switch out the breather cap for the dress-up chrome version. No dice, unless I want to trim down the oil fill pipe. Put that in your oil fill pipe and smoke it, haha.
Old 04-16-2023, 09:18 AM   #18
KULTULZ
KULTULZ's Avatar
That addition is very much appreciated ...
Old 04-16-2023, 10:47 AM   #19
russonator
russonator's Avatar
The visuals:
Old 04-16-2023, 06:03 PM   #20
KULTULZ
KULTULZ's Avatar
Again, that info is muchly appreciated. I was never a fan of the FYB until I stumbled across y-blocksforever.com and saw what those guys were doing with them.
