Old 01-28-2019, 08:03 PM   #1
39pu
Default What is it.
Both water pumps are off my 59A and when I look in the cavity I can see what looks like an electrode hanging down in the block. What would I be seeing.
39pu is offline   Reply With Quote
Old 01-28-2019, 08:06 PM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: What is it.
Temperature Sensor???
Phil NZ
Phil Gillespie is online now   Reply With Quote
Old 01-28-2019, 08:09 PM   #3
39pu
No sensors in the area.
Old 01-28-2019, 08:09 PM   #4
Kube
Kube's Avatar
Anti-corrosion device?
How about a picture and we can all stop guessing?
Old 01-28-2019, 08:09 PM   #5
B-O-B
B-O-B's Avatar
wire from the casting of the block.
B-O-B is offline   Reply With Quote
Old 01-28-2019, 08:10 PM   #6
39pu
Looks like a wire electrode with a 90 degree bend at the end.
Old 01-28-2019, 08:11 PM   #7
39pu
I don’t know how to do pics. Could be some kind of anode?
Old 01-28-2019, 08:14 PM   #8
Flathead Fever
Flathead Fever's Avatar
If its the size of rebar tie-wire, it could have been holding a sand core in place when they poured the cast iron.
You guys are fast. By the time I wrote my sentence four others chimes in. We definitely need a photo, I'm really curious to see this thing.
Flathead Fever is offline   Reply With Quote
Old 01-28-2019, 08:34 PM   #9
Kube
Kube's Avatar
Judging by where it is, that was my guess (previous post).
Old 01-28-2019, 08:50 PM   #10
FortyNiner
FortyNiner's Avatar
Block heater?
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 01-28-2019, 10:50 PM   #11
Lanny
Lanny's Avatar
Click on picture to Enlarge.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 01-29-2019, 07:01 AM   #12
51 MERC-CT
51 MERC-CT's Avatar
As stated, nothing more than un-trimmed wire that was used to fasten/stabilize
the components during the casting process.
These are examples in an 8BA block.
Old 01-29-2019, 09:11 AM   #13
JSeery
JSeery's Avatar
Inside of the blocks are often full of this kind of stuff.
Old 01-29-2019, 09:16 AM   #14
Cecil/WV
Cecil/WV's Avatar
I've seen this before. It is as already stated.
Cecil/WV is offline   Reply With Quote
Old 01-29-2019, 11:06 AM   #15
V12Bill
V12Bill's Avatar
xx2
V12Bill is offline   Reply With Quote
Old 01-29-2019, 11:13 AM   #16
19Fordy
19Fordy's Avatar
That's a core wire. I found them when cleaning my block back in 1973.
Looks like a 1/8 welding rod with no flux.
Old 01-29-2019, 08:39 PM   #17
old Tom
That's what I learned to weld with My Dad said once you can weld with that the other would be easy.
old Tom is offline   Reply With Quote
