Old 11-11-2019, 04:52 PM   #1
nosoup4u
Default Making an A axle steer easier
Now that winter has set in, I'd like to do some work on this thing to make it a little more drivable. One of the problems is that it steers hard. Part of the problem is likely the Deere steering sector I used, which is definitely not designed for running a model A front axle, but I wanted to use as many Deere parts as possible. Also the steering wheel is a little small.
It needs new king pins badly, which I will also change this winter, but what else might I try to make it steer a little easier?
nosoup4u is offline   Reply With Quote
Old 11-11-2019, 06:32 PM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: Making an A axle steer easier
Don’t change king pins. Just new bushings. Easy.
Old 11-11-2019, 06:45 PM   #3
40 Deluxe
Try removing some weight. Switch to an aluminum radiator, for starters. Get the block and heads recast in aluminum also. Have the flywheel lightened. Take off oh, maybe 150-200 pounds. Drill some holes in the frame and front axle. Let us know if this helps!
40 Deluxe is online now   Reply With Quote
Old 11-11-2019, 06:55 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
An improperly shimmed spindle bolt bearing will make one very hard to steer. Make sure the load of the spindle is actually being supported on the spindle bolt bearing, -and not the spindle rubbing on the axle beam boss.
Next, I would say the steering on the tractor was/is likely worn however the box should have many turns from lock-to-lock. Disconnect the Pittman arm to see whether the steering gearbox is turning stiffly or whether it is in the steering arms and tie-rod ends. I cannot see what you are using for tie-rod ends, but if they are stock Model-A type, they may be adjusted incorrectly with too much spring tension.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-11-2019, 08:13 PM   #5
Jacksonlll
Jacksonlll's Avatar
The king pins are in tension. The car hangs from the king pins, that are supported by a bearing at the top. Make sure this is what you have
Old 11-12-2019, 09:28 AM   #6
nosoup4u
What is this?
Old 11-12-2019, 09:30 AM   #7
nosoup4u
I'm using A tie rod ends.The balls on the tie rods and drag link from the A are the same size as the John Deere.
Is there a general rule of thumb as to how tight the tie rod ends should be? Do those Teflon inserts do any good?
Old 11-12-2019, 10:09 AM   #8
Corley
First off, you have done a beautiful job on your creation. I appreciate your creativity.
Steer easier? Lub the crap out of it, test with the weight removed from the wheels to find out if the king pin thrust bearings are doing their job, weight back on it, remove the tie rod to test if the problem is in the left or right side, remove the drag link to see if in the gear or front axle, etc.
I'm going to assume you have done all that and it still steers hard. Model As don't have power steering! Try not to fight it, and only turn the steering wheel when the car, tractor, er, eh, "vehicle" is moving, this will help. You could go to easy steer, or the F100 steering box.
Good luck, I can see you are having fun, more power to you!
Corley
Subscribed to the KISS principle!
Corley is offline   Reply With Quote
Old 11-12-2019, 10:41 AM   #9
old31
I am curious. Why only change the bushings?
old31 is offline   Reply With Quote
Old 11-12-2019, 10:44 AM   #10
nosoup4u
I'm more of a tractor guy than car, so you'll have to do some splainin to me. When I jack up the front axle, what am I looking for besides obvious looseness in the king pins?
Old 11-12-2019, 11:37 AM   #11
Jim Brierley
Nice looking rig, had hoped to see it in Lincoln last May.
With new king pins and bushings installed and everything lubed, and it still turns hard, shorten the pitman arm. This will give you more mechanical advantage. A good welder can do this safely, cut on an angle to give more weld-length, thus stronger than butt weld. Also the drag link should be as near horizontal as possible so you are not trying to lift the car as you turn.
Old 11-12-2019, 12:36 PM   #12
Corley
With the weight off of the wheels, you are only going to feel resistance from the steering components, and not the tire scrub resistance. (Note that this won't tell you much about the kingpin thrust bearing, which could also be binding.) You are simply trying to isolate the various place where binding could potentially occur.
Corley
Old 11-12-2019, 01:41 PM   #13
nosoup4u
Last May it was still in 14 pieces.
Old 11-12-2019, 02:28 PM   #14
dumb person
dumb person's Avatar
A good welder can do this safely.
Not sure that's a good idea. It's extremely illegal in my country & a major reason why imported cars can't be road legal.
Just so people know...
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 11-12-2019, 04:10 PM   #15
Synchro909
Synchro909's Avatar
Are you complaining about hard steering while the vehicle is stationary or moving? If it is heavy at zero or very low speeds, everything is normal. I don't know whether this applies to you, but there are many people these days who have never driven a vehicle without power steering so they think the world is at an end when they do.
There may be nothing wrong.
Old 11-12-2019, 10:05 PM   #16
Pete
Pete's Avatar
Heavy steering is a way of life with old cars and tractors. There are several things that can be done.
1- Live with it.
2- Try straight Power Punch in the gear box.
3- Install an early Nash power steering. Most cars require NO mods to the existing steering
for it. It will most likely require fabrication of a pump mount. On your car the running
board apron would hide the cylinder. The cylinder bears on the pitman arm.
Old 11-13-2019, 12:26 AM   #17
mike657894
mike657894's Avatar
mine steers easy. something is probably binding it up. good luck. I pray to the gods of iron its not expensive.
mike657894 is offline   Reply With Quote
Old 11-13-2019, 12:19 PM   #18
Jim Brierley
I welded mine in 1959, still doing well. Bevel the joint deeply, weld, peen, weld, etc. Peening is important as it relieves stress.
Old 11-15-2019, 08:48 AM   #19
burner31
burner31's Avatar
A "little" better view
Keith
Shawnee OK
'31 SW 160-B
Old 11-16-2019, 09:56 AM   #20
eagle
eagle's Avatar
Obviously you are very comfortable with modifications and fitment so why don't you find a steering box off of an old truck. Some of those you had to turn the wheel many revolutions to go lock to lock. I would think you could google it to find the ratio you want.
By the way, how many revolutions of the wheel is it now for lock-to-lock?
